Any thoughts on using Lucas Oil Stabilizer? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 12th, 08, 12:23 PM Thread Starter
I recently changed my oil and added the Lucas Oil Stabilizer. Afterwards I seen this link.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
After seeing this, I don't know what to think. I find it hard for NHRA and many other credible sources endorsing a product that would be bad for your engine. I dont know if I completely support the findings from the tests. Does anyone feel strongly for or against the Lucas Oil Stabilizer. Any others have personsonal experience with the product?
mike65red is offline
post #2 of 4 (permalink) Old Apr 12th, 08, 04:11 PM
Chris
Re: Any thoughts on using Lucas Oil Stabilizer?
I use it.....no bearing problems in my engines.
68 Camaro, 555 big block, Doug Nash 5-speed, 3.54 gear.
smits67 is offline
post #3 of 4 (permalink) Old Apr 12th, 08, 08:09 PM
I just switched to a retrofit roller cam. I was tired of loosing flat tappet lobes.
lluciano77 is offline
post #4 of 4 (permalink) Old Apr 12th, 08, 08:45 PM
Greg
Same here. Glad I do not have to worry about that anymore.
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
emperor91108 is offline
