TH350 Kickdown bracket for Vortec Manifold - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 13th, 08, 06:16 PM Thread Starter
Clint
Does anyone know what kickdown cable bracket to use with an Edlebrock manifold for vortec heads. The bracket I had won't fit the vortec manifold because the bolt pattern (8 bolts vs. 12) is different. I looked in Summit but did not see a bracket designed for the vortec manifold.
Clint
cwb90 is offline
post #2 of 4 (permalink) Old Apr 13th, 08, 06:35 PM
Re: TH350 Kickdown bracket for Vortec Manifold
either get one that mounts to the carb, or fab up some sort of a simple adapter.
or just leave the kickdown unhooked. it won't hurt anything.
you don't plan sincerity.
novaderrik is offline
post #3 of 4 (permalink) Old Apr 14th, 08, 07:39 AM
I normally stear away from anything with Mr. Gasket written on it. However, they make a bracket that mounts onto your carb stud and it will allow you mount the kickdown cable and throttle cable. I did have to do some grinding on the bracket to make it fit correctly, though. Any auto part store will have it in their "hot rod" parts area. I think it was around $15 bucks.
middleagecrisis is offline
post #4 of 4 (permalink) Old Apr 14th, 08, 08:36 AM
keypilot's Avatar
i got one from Lokar but have not mounted it up yet.
I feel your pain.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
keypilot is offline
