Which Headers to buy? - Team Camaro Tech
post #1 of 15 (permalink) Old Apr 13th, 08, 07:47 PM Thread Starter
I have a 383 small block putting out 472 hp. I need headers for this engine. I just had the engine built and need headers, but don't want to break the bank. Which have the best fit and clear the spark plug boots? Also what diameter tubing would be best? Thanks, ED.
Eds toy is offline
post #2 of 15 (permalink) Old Apr 13th, 08, 07:55 PM
class67's Avatar
Re: Which Headers to buy?
Hooker Super Comp's, 1 3/4".
67 Camaro RS
class67 is offline
post #3 of 15 (permalink) Old Apr 13th, 08, 07:57 PM
If you really want bang for the buck. I got the summit coated headers for less that 200 bucks. You may or may not have to put a small dent for the steering column. You can look in my profile pick to look at them. I think the uncoated ones are like 80 bucks.
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi.
justincat is offline
post #4 of 15 (permalink) Old Apr 13th, 08, 08:28 PM
Those are 1 5/8" though right? I would go with 1 3/4". Hooker Super Comps are nice but the metal is thin. Hedmans have thicker tubing and flanges.
lluciano77 is offline
post #5 of 15 (permalink) Old Apr 13th, 08, 08:32 PM
yep they dont even make them in summit coated in 1 3/4. good looking out.
post #6 of 15 (permalink) Old Apr 13th, 08, 09:10 PM
Dustin
I got my ceramic coated Sanderson headers for $415 shipped.
68 Camaro (In the works)
01somta is offline
post #7 of 15 (permalink) Old Apr 13th, 08, 09:22 PM
What headers did you dyno the motor with?
I would go with a 1-5/8" header, you spend a lot more time in the range that they operate well than the range of the 1-3/4" headers.
Performance Welding Racing Headers has the following to say:
So being very general, a low horsepower 350 CID V8 engine making only 1.5 horsepower per CID (525 hp) may only require a primary tube size of 1 5/8"stepped to 1 ¾". This particular engine would only require a merged collector throat size of approximately 2 ¼" with a 3" outlet. The primary tube length is dictated by what RPM the engine is run at to obtain these power levels, with the vehicle weight, transmission, torque converter, and type of racing playing a dominating role.
onovakind67 is offline
post #8 of 15 (permalink) Old Apr 14th, 08, 06:33 PM Thread Starter
I'm not sure what headers they used. I was there when the motor was on the dyno. If I remember right they had the headers upside down and going into 5" flex tubing out the back of the building. Then they can run a wide variety of engines that way. He also stated different headers are going to perform differently. He recommended contacting header manufacturers with my engine numbers and they could do a better job of recommending. Thanks for the advice, ED.
So being very general, a low horsepower 350 CID V8 engine making only 1.5 horsepower per CID (525 hp) may only require a primary tube size of 1 5/8"stepped to 1 ". This particular engine would only require a merged collector throat size of approximately 2 " with a 3" outlet. The primary tube length is dictated by what RPM the engine is run at to obtain these power levels, with the vehicle weight, transmission, torque converter, and type of racing playing a dominating role.
Eds toy is offline
post #9 of 15 (permalink) Old Apr 14th, 08, 09:12 PM
Look at the headers this guy used:
http://www.tonybarkerracingengines.c...NGINETEST.html
post #10 of 15 (permalink) Old Apr 15th, 08, 09:13 AM
JcGc's Avatar
I bought my headman 65003 1 3/4 headers from Jet Hot. Delivered to my door was $500.53
1969 Camaro
JcGc is offline
post #11 of 15 (permalink) Old Apr 15th, 08, 09:20 AM
DeAngelo
Hooker headers will be about 2 inches from the ground on the driver's side. I returned mine for that reason. If you are racing, no problem. If it is a street car like mine, you will hate it when you scrape the street every 4 blocks. I chose the Thorley headers and was VERY pleased. I have a 383 with 440 HP. They tuck under nicely. I have factory AC and I had to modify the headers by cutting a piece out and then I sent it to Jet Hot for recoating. Keep us posted. DeAngelo
Deangelo66 is offline
post #12 of 15 (permalink) Old Apr 15th, 08, 04:06 PM
Greg
Make sure to get them ceramic coated or you will end up doing it later. I ended up having to get my Hooker Comps ceramic coated later for $175 at a local shop. In my case they cleared the power steering by a 1/4", but are kind of low on the drivers side. Another hidden cost of getting headers is having to go to a mini-starter.
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
emperor91108 is offline
post #13 of 15 (permalink) Old Apr 15th, 08, 05:05 PM
Brandon
When I finally buy some I will buy these, http://store.summitracing.com/partde...5&autoview=sku
I had a set of thorleys on an old project, worth the money. THICK flanges never leaked and check out this thread to see pics of how tight they tuck under a first gen!!
https://www.camaros.net/forums/showth...=102486&page=3
Pix of my cars...
brandonc707 is offline
post #14 of 15 (permalink) Old Apr 15th, 08, 09:47 PM
I just dropped a new ZZ383 in my '69 this last weekend. I used Doug's D-368's. They seam to have good clearance all around. I did have to slot the flange holes because of the D-port exhaust ports. They still fit fine. This with stock P/S setup.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #15 of 15 (permalink) Old Apr 16th, 08, 09:03 AM
TC
Fred,
what is the difference btwn the D368 and DTE-376Y1 everyone uses? Did you slot the bolt hols down from the original postion? I'm going to be ordering a ZZ385 here soon and will be needing to do the same thing I hear. What did you use to slot the holes? thanks for the info.
6Z8RS is offline
