Order/Finding custom head gaskets? - Team Camaro Tech
post #1 of 15 (permalink) Old Apr 13th, 08, 08:12 PM Thread Starter
AJ
Is there any place to call or go online to order custom head gaskets? Maybe not custom but rare/hard to find?
I decided not to use the .015" shim steel gaskets because I am using aluminum heads, have old gasket on the block that needs to be scraped off which could cause scratches leading to sealing problems.
I'm looking for a composition type gasket with a 4.040" minimum bore and .028" thick compressed (or lower if possible).
I have found a .028" fel pro but summit only lists it as 4.000" bore and my motor is 4.040" so that would not work.
Thank You!
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #2 of 15 (permalink) Old Apr 13th, 08, 08:26 PM
Re: Order/Finding custom head gaskets?
I'd be careful of a thin gasket with cast iron to aluminum. Check with the manufacturer to see if what you choose can be used with aluminum heads. Undercut studs will help a little in the dissimilar expansion rates.
lluciano77 is offline
post #3 of 15 (permalink) Old Apr 14th, 08, 04:51 PM
I have to believe Fel-Pro know's what they are talking about when THEY say it's OK to use their rubber coated .015" thick shim #1094's w/ aluminum heads!
So go from there!!
pdq67
post #4 of 15 (permalink) Old Apr 14th, 08, 05:10 PM
Chad
67 Plum's Avatar
Victor Reinz part #5746 4.100 bore .026 compressed.Its a composite gasket available from your local auto parts store.Or you cam order them from www.Competitionproducts.com $14.95 ea.http://www.competitionproducts.com/p....asp?dept=1190
67 Plum is offline
post #5 of 15 (permalink) Old Apr 14th, 08, 05:26 PM Thread Starter
AJ
Dude you are a GOD in my book!
I looked high and low for these suckers!
these should seal better than the .015" shim steel's right?
and whats the deal with "race only" should I just ignore that and buy them?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #6 of 15 (permalink) Old Apr 14th, 08, 06:00 PM
Bill
Thank You!
AJ,
Most gaskets are listed for the "basic" bore size of the engine. They will generally easily work up to at least .060" over bores. Which Fel-Progasket number is it ??
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #7 of 15 (permalink) Old Apr 14th, 08, 06:05 PM Thread Starter
AJ
Originally Posted by BillK View Post
AJ,
http://store.summitracing.com/partde...7&autoview=sku
That is the gasket.
I was scratching my head on the 4.000" bore size, I even called scummit and they said they only carried the .028" in a 4.000" bore size, they said if i provide a part # from felpro with the correct bore size i can order it through them.
Im just going to order the victor Reinz gasket mentioned above.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #8 of 15 (permalink) Old Apr 14th, 08, 06:17 PM
Chad
67 Plum's Avatar
Not sure about the race only.My local Bumper to Bumper stocks them.Have used them on street engines with no problem.Nothing about race only on the package.
67 Plum is offline
post #9 of 15 (permalink) Old Apr 15th, 08, 06:32 PM
Bill
AJ,
That gasket will work up to at least .060 oversize.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #10 of 15 (permalink) Old Apr 15th, 08, 06:46 PM
So go from there!!
pdq67
Whcich do you think will conform better to irregularities, .039" or .015"? The difference in expasion between cast iron/aluminum is more so than that of cast iron to cast iron. I guess "OK" is a matter of opinion and luck.
post #11 of 15 (permalink) Old Apr 16th, 08, 04:58 PM
Imho!
Right, flat surfaces checked by me!
If Fel-pro say's I can use their #1094's on aluminum/cast-iron and both cast-iron, I take it to the bank b/c THEY made them!
And I've installed two .020" thick steel shims on my 11.5 to 1 Cr'd, .060" overbore 409 "W" engine years ago FINE and also hand fit .020" thick, 350 engine shims for installation on my 406 SB fine!
I used good old Permatex, "Indianhead Shellac Gasket Cement" on the 409 "W" engine's stacked headgaskets and dauber bottle, CopperCote on my 406 SB!
And I'm almost anal about retorqung headgaskets at least three time's over as many day's, hot/cold cycling them!!
Darned headers take like 6 or 7 time's to get them TIGHT!!!
pdq67
post #12 of 15 (permalink) Old Apr 16th, 08, 06:18 PM
get cometic thin gasket with coating on it Cometic has a website
prostock is offline
post #13 of 15 (permalink) Old Apr 16th, 08, 06:28 PM
Imho!
pdq67
Well, I guess you have a lot more guts than me. Maybe I am just too conservative playing it safe.
post #14 of 15 (permalink) Old Apr 16th, 08, 06:40 PM
Harley
wiskeesour's Avatar
AJ Ive been using Fel-pro .015 gaskets on all my motors that are 25 in the hole. Never had a problem with them.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #15 of 15 (permalink) Old Apr 17th, 08, 04:52 PM
Right wiskee!
If you can't believe the people that make them, who can you believe??
Just check both decks is all and go.
As for messing w/ stacked shims, GM used to do it stock to lower the CR some in those time's!
pdq67
PS., oh, and btw, isn't Cometco Detroit Gasket??
