Will AMP gauge work with One-Wire setup? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 14th, 08, 12:57 PM Thread Starter
Dan
Installing center console with the gauge package - stock looking 98 console & gauges.
The alternator on the car now is a one-wire late model setup. Do I need to use a different alternator to get the AMP gauge to work properly, or is there a way to wire up the AMP gauge to the one-wire alternator and have it display the proper amp drain?
Dan
1968 RS - Black
408 w/ Muncie 4 speed & 12 bolt rear
Deluxe Houndstooth Interior
Dropped 2" with TeamIII Mini-Lites
Click for Picture:
funbnme is offline
post #2 of 6 (permalink) Old Apr 14th, 08, 01:02 PM
Re: Will AMP gauge work with One-Wire setup?
You shouldn't have to change anything to have a working ammeter.
onovakind67 is offline
post #3 of 6 (permalink) Old Apr 14th, 08, 01:06 PM
As long as the "one wire" is connected to the horn relay, the ammeter will work fine.
post #4 of 6 (permalink) Old Apr 15th, 08, 05:20 AM Thread Starter
Dan
Anyone have a good wiring diagram I could refer to? Not sure what you mean about hooking up the alternator wire to the horn relay. I tried a search, but couldn't find a relevant post.
Dan
1968 RS - Black
Click for Picture:
funbnme is offline
post #5 of 6 (permalink) Old Apr 15th, 08, 05:37 AM
If the stock alternator wire (big red one) was used, the ammeter will be OK.
If a new one was run, and it was run straight to the battery, the ammeter will never show "charging"
There are wiring diagrams linked in the electrical basics sticky.
post #6 of 6 (permalink) Old Apr 15th, 08, 02:12 PM
Carl
It also will not read correctly if an oversized wire was used between the relay and the distribution block. A voltmeter is better IMO for this case.
CarlC is offline
