Flywheel Removal Procedure?? - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 14th, 08, 07:50 PM Thread Starter
I need to remove my flywheel to have it balanced. Do I use a puller like the one used to pull the steering wheel? It is on the crankshaft tight and I am looking for the right procedure. Do not want to damage it either.
Thanks!
Countryside_Cafe is offline
post #2 of 7 (permalink) Old Apr 14th, 08, 08:02 PM
Robert
Re: Flywheel Removal Procedure??
No puller needed. Tap it with a dead blow hammer or wood block and hammer and it should come off. Might want to put a couple of the bolts back in just barely so it doesn't hit the floor or yourself when it comes loose.
Robert
TC member #18
rojo is offline
post #3 of 7 (permalink) Old Apr 14th, 08, 08:02 PM Thread Starter
Good - Thanks!!
post #4 of 7 (permalink) Old Apr 14th, 08, 08:03 PM
If you have all bolts out, dowel may be only thing holding it with maybe a little dirt and rust. I would put a bolt or two back in and tap outer edges with a rubber or wooden mallet to loosen up. It should start wobbling off as you tap all around edges. Becareful it does not fall off , on you .
TC # 349
zdld17 is offline
post #5 of 7 (permalink) Old Apr 14th, 08, 08:26 PM Thread Starter
OK, I will try that too since it is in the car and not a lot of room to hammer underneath. Like the idea of leaving a few bolts in also.
post #6 of 7 (permalink) Old Apr 15th, 08, 04:59 AM
Or get a prybar between the block and pry out.
Yep, hate to read/see the effect when a 30 lb flywheel and gravity are mixed together.
post #7 of 7 (permalink) Old Apr 15th, 08, 04:50 PM
And watch it b/c the ring gear teeth can eat you alive if they are worn any and SHARP!!
Careful, careful, careful!
pdq67
