SBC stupid question - Team Camaro Tech
post #1 of 20 (permalink) Old Apr 14th, 08, 08:20 PM Thread Starter
SBC stupid question
I know this is probably a stupid question but why does some SBC's have an oil filler tube in the front of the motor and some dont??
Tacoma Tom is offline
post #2 of 20 (permalink) Old Apr 14th, 08, 08:23 PM
Harvard
Re: SBC stupid question
Way they were designed. 67 and 68 Camaro had oil fill tubes up front. 69's had them in the valve cover.
1968 Z28 British Green, all original except CE 302 engine. Have original owners booklet and protect-o-plate.
68zproject is offline
post #3 of 20 (permalink) Old Apr 14th, 08, 08:24 PM Thread Starter
But some of the intakes i see have the oil filler tube in the front. Does it matter? I suppose they are interchangable??
post #4 of 20 (permalink) Old Apr 14th, 08, 08:27 PM
Ron
Prior to the PCV system SBC motors vented the crankcase threw an Outlet tube usually found on the back of the intake manifold next to the distributer so it was practice to put an Oil Filler tube on the Front of the intake as there was room for it at this location. Newer engines got a PCV system to vent the crankcase and as more accessories were bolted onto the front of the engine they took up space were the filler tube was - so the Oil Filler Tube on the front of the intake had to go and is now usually found on a valve cover.
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 20 (permalink) Old Apr 14th, 08, 10:48 PM
Harvard
Depends on what you're trying to use the intake for. Are you restoring a car to originality? Each manifold is specific to an application. The 67 and 68 Z28's have the thermostat housing in the middle and the 69 has it off center. They also have different casting #'s. I can't speak to every model, but most have certain casting numbers for each engine combo.
post #6 of 20 (permalink) Old Apr 15th, 08, 06:22 AM
Jerome
Ditto on the above Tom and never a stupid question thats how we learn ...Hi Harvard: hope the new year been good to you ,very good here lots of new parts going together to make a good setup I hope,see ordered wednsday in the performance forum if interested ,hope we can all get together this summer,sorry Tom didn't mean to hijack.... Happy Motoring
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #7 of 20 (permalink) Old Apr 15th, 08, 01:42 PM
Fred
Originally Posted by Old baldguy View Post
Ditto on the above Tom and never a stupid question thats how we learn ... Happy Motoring
128.79mph 1.428 60'
Fred Ficarra is offline
post #8 of 20 (permalink) Old Apr 15th, 08, 02:01 PM
Jerome
Originally Posted by Fred Ficarra View Post
Hope to see you too this summer Fred ,I am not good at planning ,but maybe a collective effort ,for the Puget Sound area T/C gang...Happy Motoring
post #9 of 20 (permalink) Old Apr 15th, 08, 02:48 PM
Vintage 68's Avatar
Wink Re: SBC stupid question
Originally Posted by Z15CAM View Post
Prior to the PCV system SBC motors vented the crankcase threw an Outlet tube usually found on the back of the intake manifold next to the distributer ...
Just to clarify;
Prior to the PCV systems - there was a "Draft-tube" system that allowed vapors to flow from the fill tube vented cap inlet, through the block and be drawn out of the draft-tube by the negative pressure differencial at the tube outlet. The vapors and crankcase bi-products were dumped into the air flow under the vehicle.
These draft-tube systems were never installed on Camaro engines from the factory.
The 'outlet' for the crankcase vent was cast into the rear of Pre-1968 blocks (for automotive use - marine, industrial and truck continued for several more years) - not the intake manifold.
Inlet vent air to the crankcase entered via the cap on the oil fill tube on "Open" PCV systems and through the rear vent on "Closed" PCV systems (a reversed flow to the 'open' venting design).
The PCV valve was mounted in the rubber tubing leading from this rear vent hole to the intake on 1967 "Open" systems.
The PCV valve is screwed into the fill tube and routed to the intake via rubber hose on the 1967 "Closed" systems.
There was also an oil-seperator installed internally in the block lifter galley (below the manifold) that caught most of the oil out of the vapors exiting the vent hole.
1968, and later, automotive blocks do not have the rear venting provision hole and used the valve cover holes to allow crankcase vapors to be vented to the intake to be burned off during operation.
The passenger (right) side is the inlet side to the crankcase vent air flow of the post-68 PCV systems and the PCV valve is mounted in the Drivers (left) side valve cover (or in the tubing run of a few set-ups) as the vapor outlet to the intake system for the vapors to be burned.
1968 Convertible
Some trucks
Vintage 68 is offline
post #10 of 20 (permalink) Old Apr 15th, 08, 04:28 PM
Ron
John:
Great info re PCV history. Come to think of it I do recall seeing that Oil Baffle Canister in the lifter gallery on older blocks but man - that was some time ago - LOL
Z15CAM is offline
post #11 of 20 (permalink) Old Apr 15th, 08, 04:44 PM
You ever get behind an old car in traffic and see steam coming out from under it?? And it stunk of unburned crap!!
That's the engine ring blow-by that is expelled out the road draft tube!! EPA said it caused right a 35 percent or so of ALL vehicle smog forming air pollution emissions so it was done away first out in Cali like about '63/'64!
pdq67
post #12 of 20 (permalink) Old Apr 15th, 08, 06:00 PM
Harvard
I've got a 50 Buick with the tube out the back of the block. Smells like nostalgia.
post #13 of 20 (permalink) Old Apr 15th, 08, 06:05 PM
Ron
I guess they didn't attempt to dump the draft tube into the OIL Bath Breather for fear of flooding it with oil or causing a Crank Case explosion.
Z15CAM is offline
post #14 of 20 (permalink) Old Apr 15th, 08, 07:41 PM
Vintage 68's Avatar
Talking Re: SBC stupid question
... but man - that was some time ago - LOL
Yeah, I'm old - go ahead and rub it in
ps: tomorrows lesson will be the art of 'scraping babbit' - be sure to tune in
1968 Convertible
Some trucks
post #15 of 20 (permalink) Old Apr 15th, 08, 11:06 PM
Ron
John: I learned to drive in a 55 Ford in 66 - so take it from there. Don't tell anyone but it was faster the a 56 Pontiac and left a 56 Olds 98 behind - LOL
Z15CAM is offline
