bent guide rods - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 15th, 08, 08:05 AM Thread Starter
bent guide rods
What will make tow rods bend? I took the 406 back to the engine builder and have it tear it down. The number 5 and 7 guide rods are bent. The pistons are fine and he is taking it down further to check the crank and bearings. So far it looks like its just the two rods. Said that there was odor of like old gas and the rods had a sludge like material on them. Asked how long after it was broken in it sat. It sat little over 2 weeks until I had the days off to install. Put it in, ran like a champ. Its when the distributor got loose and messed up the timing that it went down hill. Question still is- what contributed to the bent rods. Looks like its going to be 300 bills out of pocket. Thats okay because I bought the engine in 06 and there is only a year warranty. This just recently happened about a month ago.
69DMZ is offline
post #2 of 6 (permalink) Old Apr 15th, 08, 05:01 PM
Re: bent guide rods
Guide rods? Tow rods?
Are you talking about connecting rods? Pushrods?
Old gas smell doesn't mean anything. Neither does sitting in a garage longer unless there is moisture, corrosion, and rust.
Sludge on the rods? What color? If it's chalky yellowish/white that would be coolant or moisture. Greyish/black could be assembly lube???
lluciano77 is offline
post #3 of 6 (permalink) Old Apr 18th, 08, 09:02 AM Thread Starter
Re: bent guide rods
Pushrods. Number 5 and 7 had no compression. Took the heads off and the rods were bent. I should know more friday. The rods were gunked up.
69DMZ is offline
post #4 of 6 (permalink) Old Apr 18th, 08, 06:25 PM
Re: bent guide rods
If you have no compression I would check that your valves aren't bent also. Get some new rods and check the compression again.
post #5 of 6 (permalink) Old Apr 19th, 08, 12:05 AM Thread Starter
Re: bent guide rods
Both the valves and rods were bent. Picking up the motor on Monday.
69DMZ is offline
post #6 of 6 (permalink) Old Apr 19th, 08, 05:59 AM
Re: bent guide rods
So somehow the valves hit the pistons.
What RPM did you spin it to?
Most likely you floated the valves.
What cam, springs, size valves, and type of piston?
I would imagine a flat top piston right? Tell me what your cam specs are @.050" also. Speaking of the cam, did you check your cam to rod bolt clearance? Once I hear the cam specs I'll know if this may be an issue.
