Small block rods - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 15th, 08, 05:49 PM Thread Starter
Small block rods
I bought a 327 in pieces the other day. All the resized rods are in a box. It's been a while, but the wide flat parts of the big end go against each other, right? Other than that, there's no "front" or other orientation to worry about, right? Just checking. Thanks.
go2fast is offline
post #2 of 11 (permalink) Old Apr 15th, 08, 06:26 PM
Bill
Re: Small block rods
Jim,
On a Chevy engine the easiest way remember is that the bearing locating "tangs" go out towards the oil pan rail.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 11 (permalink) Old Apr 15th, 08, 06:39 PM
Ron
Other then the tangs, the chamfered radius on the journal rod end is installed facing outwards toward the crank counter weights. This is to accommodate the radius on the journal of the crank. You will note that most rod insert bearings will also have this chamfer aswell.
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 11 (permalink) Old Apr 15th, 08, 07:50 PM Thread Starter
Thanks guys!
go2fast is offline
post #5 of 11 (permalink) Old Apr 16th, 08, 05:00 PM
And the oil holes go towards the cam if they still have them?
pdq67
post #6 of 11 (permalink) Old Apr 16th, 08, 05:45 PM
And remember the pistons can be different too. 4 eyebrow flatops don't matter, but if you have 2 valve relief pistons, you'll have 4 left sets and 4 rights. If you're assembling with floating pins, you'll need to pay attention to this.
post #7 of 11 (permalink) Old Apr 16th, 08, 07:51 PM Thread Starter
Out of curiosity, why would floating pins be any different than pressed? Wouldn't I have to worry about it either way?
go2fast is offline
post #8 of 11 (permalink) Old Apr 16th, 08, 08:10 PM
I assume that you, like me, do not have the equipment to press our own pins.
"someone" does have to worry about it, that someone is the machinist who is hired to do the pressing.
All "we" have to do is make sure the chamfers are out for both rods on each crankpin.
post #9 of 11 (permalink) Old Apr 16th, 08, 08:24 PM
Tim
77wolf10.85's Avatar
Yes you need to worry about it either way. I don't want to put words in Jim's mouth but I think he was just thinking most folks don't fool with press fit pins at home. I do em at home but if I goof one I consider the piston trash. I'm not good enough to get em back apart without tearing hell out of em. I get the rod back but I'm usually huntin another piston. Maybe a few I've not trashed, very few. Crap is brittle.
I suggest laying everything out and getting thoroughly familiar with it. The pistons may have notches you put forward, and then you have to pay attention to the eiieeiie pattern of the valves(if the vr's aren't identical)...in addition to getting the left bank rod chamfers forward and the right bank chamfers to the rear. If you're dealing with a set of un-numbered rods it makes it easier, you just put 4 left bank rods on 4 left bank pistons etc.
Tim Smith
77wolf10.85 is offline
post #10 of 11 (permalink) Old Apr 17th, 08, 02:47 PM Thread Starter
OK, I see now. I do have a press at home. I got tired of having to get others to do my stuff years ago.
go2fast is offline
post #11 of 11 (permalink) Old Apr 17th, 08, 04:29 PM
If the pistons are stock type, 4-notch, install them backwards so you get the usual .060" pin offset better under the rod thrust!
Doing so will allow them to cold-slap more until they are warmed up, but I figure a little noise is worth the better rod angularity up top.
And this is an old "shade-tree" trick..
pdq67
