383 Flywheel - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 17th, 08, 07:47 PM Thread Starter
383 Flywheel
I have a new 383 that is externally balanced. It also has a one piece rear seal. Is the flywheel for a one piece seal block different from a two piece? I thought they all used 400 flywheels if they are externally balanced.
737IP is offline
post #2 of 6 (permalink) Old Apr 17th, 08, 08:10 PM
Harley
wiskeesour's Avatar
Re: 383 Flywheel
They can be balanced for either ( I have seen and heard of both INT and EXT bal 383's) altho it makes no sense. Usually 383 are external and uses a 400 flywheel/flexplate and balancer.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 6 (permalink) Old Apr 17th, 08, 09:18 PM
Re: 383 Flywheel
The Centerforce part# for a 153 tooth flywheel is 700170. I have installed one on my project. It's a couple weeks away from fire up though. I can't give it a review at this time.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #4 of 6 (permalink) Old Apr 17th, 08, 09:28 PM Thread Starter
Re: 383 Flywheel
Thanks for the quick replies.
So is there a difference between the flywheels for 2 piece vs 1 piece? If so, how do you tell the difference?
737IP is offline
post #5 of 6 (permalink) Old Apr 18th, 08, 11:19 AM
Re: 383 Flywheel
They only fit the crank flange bolt pattern for their use!
pdq67
post #6 of 6 (permalink) Old Apr 18th, 08, 06:21 PM
JohnZ's Avatar
Re: 383 Flywheel
Easy - the flywheel for a 2-piece seal engine will ONLY fit on the crank in a 2-piece-seal engine; the block, bolt pattern and crank flange on a 1-piece-seal engine is completely different, and all '86-up 1-piece flywheels are externally balanced, not neutral-balanced like 2-piece-seal flywheels. Photo below shows a 1-piece-seal setup.
JohnZ
CRG
JohnZ is offline
