89 camaro won't pass emission - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 6th, 08, 10:14 PM Thread Starter
Unhappy 89 camaro won't pass emission
took car to get emission test everything pass but the hc ppm reading 151 allowed 148. someone suggust that i drive car a while then test.
goldyiroc is offline
post #2 of 4 (permalink) Old Aug 6th, 08, 10:33 PM
Tim
77wolf10.85's Avatar
Re: 89 camaro won't pass emission
hc is unburned fuel. I'd put a set of plugs and look at the wires/cap/rotor and air filter. Like a tuneup.
151 vs 148 is awful close, your friend who suggested driving awhile may be thinking that a good drive would get the plugs to self-clean. Which is valid. And that 89 will rip all the hide off your arms doing a set of plugs if it's like the 85 we had.
151 vs 148 I think I would ask them to show me the cal on their instrument. hc cal gas (span gas) is expensive and I bet they don't have any. The way I span mine is to soak a rag in gasoline and let her whiff it, it maxes the sensor and then I cal to the sensor max. This is absolutely a non-compliance level deal though. We are not regulated on unburned hc but use it as a troubleshooting tool.
Tim Smith
77wolf10.85 is offline
post #3 of 4 (permalink) Old Aug 7th, 08, 12:55 PM
Run with more methanol (alcohol). That's what the "guaranteed to pass" stuff is. You could retard the timing a few degrees too.
go2fast is offline
post #4 of 4 (permalink) Old Aug 7th, 08, 06:45 PM
Lonnie
If you didn't drive your car for at least 45 min before the test, that is good advice.
67 Camaro [email protected], [email protected], 1.455 60ft 421sbc
Lonnie67 is offline
