Distributor decode - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 9th, 08, 04:09 PM Thread Starter
Distributor decode
May I ask at what site I can find the info. for decoding dist. #'s for decoding? I googled but came up nill. Especially the first set of #'s for I believe are the motor size it's for? The one I have extra is
1112113 4A12 Thanks in advance guys. Is that 1974 Jan.12?
Sauron67MM is offline
post #2 of 3 (permalink) Old Aug 10th, 08, 09:57 AM
Re: Distributor decode
From Chevrolet by the Numbers,
1112113, 1973/1974 only
1973 Passenger, Chevelle, Monte Carlo, 454, 215 horsepower, all transmissions,
1974, SAME AS ABOVE
Point type, aluminum, RFI/3/V - RFI ( radio frequency interference shield installed), 3 color code) - yellow, V, Vacuum advance equipped (OEM vacuum advance p/n - 1116212)
Build date 4A12, as you suspect, 4, year, 1974, A, month, January, 12, day, 12th.
Hope this helps.
Regards,
Milton
The Devil's advocate is offline
post #3 of 3 (permalink) Old Aug 10th, 08, 10:44 AM Thread Starter
That helps greatly. I've got to buy that book because I can't find that stuff on line. I wanted to know if weights and springs would be an improvement over my stock 327 dist. pertaining to the "intake manifold substitution" in the Performance Forum but at that H.P. for the 2113, I guess not. I appreciate it. Scott
