do rod end stamped numbers go on inside??? - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 10th, 08, 02:42 PM Thread Starter
Having a brain fart. Do the stamped numbers on the rod ends which tell what piston goes in what hole usually go on the inside or to the out side of the block????
dubs68camaro is offline
post #2 of 7 (permalink) Old Aug 10th, 08, 02:44 PM
Bill
Re: do rod end stamped numbers go on inside???
Out towards the oil pan rail. That is if whoever numbered them did it correctly. The numbers should be on the same side of the rod and the bearing "tang slots". They do not come numbered from the factory.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 7 (permalink) Old Aug 10th, 08, 02:45 PM
Jody
camcojb's Avatar
as Bill said, tangs out. If numbered correctly then the numbers out also.
Jody
camcojb is offline
post #4 of 7 (permalink) Old Aug 10th, 08, 05:06 PM
Ron
NOTE the Chamfer of the Rod Journal always faces toward the Crank Counter Weights not the other Connecting rod. This also confirms that you do not have the cap on reversed.
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 7 (permalink) Old Aug 12th, 08, 02:33 PM
Gary
69Z28-RS's Avatar
Another thing to remember (and I've disassembled engines that know-it-all's assembled incorrectly).. The oil slingers go adjacent to the crankshaft throws, not towards one another...
69Z28-RS is offline
post #6 of 7 (permalink) Old Aug 12th, 08, 04:57 PM
Shawn
i always say they go toward the cylinder they came from
but the oil rail works as well
victimizati0n is offline
post #7 of 7 (permalink) Old Aug 12th, 08, 05:45 PM Thread Starter
Yeah....but you always have gone through life claiming to be a "victim"!!!
