Help with rod id - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 10th, 08, 04:42 PM Thread Starter
Send a message via AIM to smith69z
Help with rod id
I have a set of rods that came with a block I bought. I am trying top find out more info on them to be able to sell them since I do not need them. The have the cyl stamped on the rod and end cap, the letters "AC" on each cap, 3 digit number I am assuming weight (618, 624, etc) and GM or CM with a A, B, C or D on the cap as well. And information on these rod would be appreciated. BTW: The block was a 302 which came with the correct 1178 crank and 30/30 cam. I ended up buying pink rods but never had the engine builder look at these rods.
69 Fathom Green RS/Z-Endura bumper - Never finished but finally certified.
smith69z is offline
post #2 of 12 (permalink) Old Aug 10th, 08, 06:24 PM
Re: Help with rod id
Depending on year, the 1967 302 have 11/32" bolts in them and press fit pins and the 1968/'69 have 3/8" rod bolts and press and floating fit pins.
I think it's the 1969 that are the stock floating rod's, but I may be off here.
Anybody know more?? I'm really not up on the so-called, "pink" rods from back then, sorry..
pdq67
post #3 of 12 (permalink) Old Aug 10th, 08, 07:24 PM
Bill
picture ?
The numbers and letters dont mean anything, just forging marks. If there are cylinder numbers stamped on them, then they have been in an engine, or someone stamped them. No Chevy rods were stamped at the factory.
What size rod bolts ? 3/8 or 11/32 ?
They sound like stock rods to me, nothing unusual.
They sound like stock rods to me, nothing fancy.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 12 (permalink) Old Aug 11th, 08, 05:48 AM Thread Starter
Thanks guys, I'll get some pics out. Hate to leave them laying around if someone could use them.
smith69z is offline
post #5 of 12 (permalink) Old Sep 8th, 08, 05:41 PM Thread Starter
These rods came with my DZ block. Trying to see if I can identify what they are.
Has AC on top, GM(A,B,C,D) on one side of the cap with the weights on the other. Has one letter on the cam end face. Some are B's, A's etc.. Any idea? Thanks
smith69z is offline
post #6 of 12 (permalink) Old Sep 8th, 08, 06:23 PM
Bill
Look like stock rods to me. Cant tell by the picture which size bolts are in them, but they are nothing special. They do look like they have aftermarket bolts in them but its hard to tell for sure by the camera angle. Looks like a dimple in the top of the bolt like ARP etc.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #7 of 12 (permalink) Old Sep 8th, 08, 07:25 PM Thread Starter
Since the block came with the correct crank and pistons I was trying to find out if these could be the correct rods for a 69 302. ARP bolts as the bolt has the lettering "ARP".
smith69z is offline
post #8 of 12 (permalink) Old Sep 10th, 08, 06:41 AM
NHBandit's Avatar
69 302 rods should be machined for full floating pins. An easy way to tell is there should be a hole in the top of the small end for oil to get to the piston pin. There should also be a letter 0 cast into the bottom of the rod cap between the bolt hole & the flat machined surface as shown in the first pic. Heavy duty Chevy SB rods will normally have the sides machined all the way to the top on the big end next to the head of the rod bolt as shown on the rod on the right in the second pic. Sometimes they will be machined all the way to the bottom next to the nut as well. A regular standard duty rod will be rough cast near the bolt head as shown on the rod on the left. Most "good" rods will have either the 0 or an X on the bottom of the rod cap. An interesting thing for anyone to remember who is looking for a low budget set of the "good" heavy duty rods is that they are commonly found in HO 305 engines from mid 80s Z/28s & Monte SS cars. They aren't "pink" rods but are the next best thing. Also forged steel 350 cranks are commonly found in GMC school bus engines from the early to mid 70s. Hope this helps.
NHBandit is offline
post #9 of 12 (permalink) Old Sep 10th, 08, 07:08 AM
Gary
Hi smith, I believe the '69 Z's were the fist ones to use the "O" rods, I'm not 100% sure (I can't find out right now) and I'm certain ALL the LT-1's had them. These were labeled as the original "pink-rods" from G.M.
I'll put a shot below comparing the original "O's" and the later "X's", substantial beam thickness!
I have access to these rods still today, I MAY even some brand new ones left! We bought many 302's years ago and immediately changed the rods to aluminum's. Very popular unit's "back when". I have dozen's used but in "mint" shape, never damaged! Some have the SPS/ARP bolt's already installed and they're balanced! I placed this "note" here because we are heavy into "resto's" in N.Y. Most have the "pink" color still visible!
(Add) You can see the "O" on the cap in the photo! That is the "pink-rod".
Thanks, Gary in N.Y.
P.S. Take a close look at the photo here, it shows the very distinct difference of why G.M. redesigned the forgings on ONLY the "pink-rods"! They are about the same in weight, but the "beams" will take much more power. Most time you work with these rods, you find "heavy" balance pads on top or bottom on most G.M.'s but NOT on the "O's", this was key issue when racing class cars years ago. Where these unit's needed a pin-end that was NOT balanced-on ("untouched") and one big-end also "untouched". Could be on the same rod and "pass"!
GOSFAST is offline
post #10 of 12 (permalink) Old Sep 10th, 08, 07:23 AM
There is no difference in the rods. They are made of the same material. The only difference is that the "pink rods" were shot peened and Magnafluxed from GM.
67 Bassman is offline
post #11 of 12 (permalink) Old Sep 10th, 08, 10:23 AM
Harry
Maybe same material but the O rod on the left in Gofasts picture looks a lot stronger. That's how it looks here. Its even said there.
Harry P. Hunter
HP Hunter is offline
post #12 of 12 (permalink) Old Sep 10th, 08, 07:14 PM
Red face Re: Help with rod id
Never mind..
pdq67
