Timing and idle RPM set up help! - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 10th, 08, 11:10 PM Thread Starter
Kurt
camsdad's Avatar
Question Timing and idle RPM set up help!
So I finally get my stroked SB fired up after several years of building up.
1st of all WOW! , and a couple of later.
All my patience seems to have paid off.
It's been about 2 weeks now since I last fired it up. Excessive work (6 days a week), couple of mini vacations, a few birthdays, list of honey do's... and yard work have kept me busy.
This idle issue has been on my mind almost every moment of the day.
I have read many other posts and still have no solution yet. Maybe I missed a post that may have helped. Been writing on this post for the last 3hrs now.
Just found one (https://www.camaros.net/forums/showth...acuum+readings) BUt I'm too tired to read anymore for now and I'm going to bed.
Mom and the kids are taking me to Monterey tomorrow for my birthday.
Oldest son wants to go on a boat to see the Whales and Dolphins.
Here's the story.
I sent my Rochester Spread Bore 750cfm Vac secondary carb off to Sean Murphy for restoration and calibration for its intended application. (Sure looks good) Throttle response is amazing. Tuning problem I am having is getting a steady idle vacuum reading. Highest vacuum reading I got was 17hg. Smoothest reading was around 15hg but the gauge bounced between (+ - 1 deg) at idle. Engine seems to like the initial timing at around 18deg. I can't get the (no load) idle RPM below 1000/1200RPM before it starts to run so rough like it is going to stall out. I have dabbled with the Air/fuel mix and timing till I had to walk away.
There does not seem to be any vacuum leak any where but I won't rule that out just yet.
What am I missing?
Should I set the carb for the best readings and then re-adjust the rockers to maybe 1/4 lash while she is running at operating temp?
Any help is very much appreciated.
Here is a basic run down of my engine setup.
385CID
10.3 compression
AFR 195 heads opened up, ported and polished a bit.
Edelbrock RPM intake
Pro Magnum 1.5 roller rockers (lash set at 1/2 turn)
Comp cams hydraulic XE274 Cam
(BTW, Valve train noise is next to non existent using Joe Gibbs BR Performance Break-in Oil)
PerTronix billet flame thrower magnetic Pickup distributor & Coil
PerTronix flame-thrower 8mm spark plug wires. Custom fit.
Bosch 7557 plugs
Holley Mechanical fuel pump 110 GPH 6.5 to 8 psi
Thorley headers ( Currently dumping into a 2" dual exhaust with Flowmaster muffs)
2.5" exhaust and Borla Mufflers on the horizon.
I did a cold compression test and here are the following psi readings.
1- 195 2- 190
3- 200 4- 190
5- 208 6- 200
7- 200 8- 200
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #2 of 7 (permalink) Old Aug 11th, 08, 12:04 AM
Re: Timing and idle RPM set up help!
it's possible that what you've got is thebest it's gonna get..
is the vacuum advance hooked up to manifold or ported vacuum?
if ported, try full manifold vacuum and re-set the idle speed screw and tune the mixture screws again. you have to do this little dance where you play with one mixture screw, then the other, then the idle speed screw, then back to the mixture screws- you do this until it doesn't get any better.
ideally, you want to do this with the car in drive- which means you need a helper that you can trust to not let off the brake pedal for a half hour while you are dangling over the front of the running engine with a screwdriver.
it might be a lot of time spent screwing around, but when it's right, you know it's right, and you feel like the god of all things automotive..
you don't plan sincerity.
novaderrik is offline
post #3 of 7 (permalink) Old Aug 11th, 08, 08:10 AM
Charlie
Kurt, I purchased a stage 2 Q-Jet from Sean Murphy and I too am having some issues. I can get my idle to below 800rpm, but I set it to 800rpm in neutral and it drops to 650rpm in drive. Perfect, but it doesn't want to stay there. When I first start to drive off, the car runs good, but then the idle wants to drop to where I have to put the car in neutral and step on the pedal to keep it running. The car also doesn't seem to have any top end. I replaced a Thunder series 650 carb and RPM Air Gap with the SMI stage 2 and RPM Q-Jet(non Air Gap). The throttle response is good, but it has no power and the idle thing gets me. I can get 15hg of vacuum and the needle is steady as a rock. That's the highest I could get. Something caught me as funny when I turned the screw all the way in and the RPM's picked up instead of stalling the engine. I sprayed brake cleaner around the base of the carb and I didn't hear the RPM's increase so I don't think I have any leaks. I don't know. I emailed Sean and I am waiting to hear what he says. I put the Thunder back on and kept the RPM Q-Jet manifold and the engine is much much better.
67CamaroRS/SS is offline
post #4 of 7 (permalink) Old Aug 11th, 08, 08:12 AM
What happens to your timing while your engine is fading away?
What screw are you turning?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 7 (permalink) Old Aug 11th, 08, 08:28 AM
Charlie
The idle mixture screws.
post #6 of 7 (permalink) Old Aug 11th, 08, 03:30 PM
Steps
That will be caused by a sudden lean ot as it runs out of fuel...same as your lawn mow, when just before it runs out of gas it speeds up the dies...
A stock factory engine with will have a hi vaccuum at idle, because of low overlap and duration...increase this and the idle vac will drop
(I have 13" at idle in neutral and 10" in gear)
Do not
set timing to highest vac or rpm at idle
Set advance to max power when all in, (this is what is important) then what ever is at idle is what u have for that dizzy spec...here u are stuck with as best idle as the engine design will give.
So start at about 36 degs all in (no vac advance connected)
What is your idle timing now? and yes with a mechanical dizzy u will get a couple degs variation.
Depending what advance u have at idle will depend if u use ported or manifold vac
Early engines used manifold with the vac advance working in a different range to later engines that used ported..they also have diff centif specs.
Once u have established the idle advance, and if using manifold or ported vac, and have these connected, then use the vac gauge to establish an idle as best the engine will give at the lowest rpms it will allow.
Steptoe is offline
post #7 of 7 (permalink) Old Aug 25th, 08, 12:57 AM Thread Starter
Kurt
camsdad's Avatar
Alrightie now.
Well the trip to Monterey for my birthday was a blast. Went out about 14 miles to see the Whales. A bit of advice.(Don't eat sea food just before you head out on the boat) My youngest son, wife, and myself ended up chumming the ocean.
I did not see the Whales but the rest of my family did. I mainly saw the back of the boat and the back of my youngest son's head as he hung over the back of the boat. LOL!
Ok, so its been 2 weeks since I last worked on my ride.
Back to my carburetor problem.
As I stated, the problem i was having was driving me nuts.(See initial post) I did not have any guidance, and if I did, I must have misplaced it somewhere.
Problem solved.
I temporary removed the TV made EZ system for now http://www.bowtieoverdrives.com/cata...php?ITEMID=221 and replaced it with a http://info.rockauto.com/Fel-Pro/Det...?60255_TOP.jpg gasket.
Idle smoothed out and vacuum reading was steady and solid. Guess I will have to get better gaskets than those that were provided with the TV made EZ kit.
Best readings I got so far is 1000 rpm Idle with 14hg vacuum @ 18 deg initial timing.
I would like to get some more vacuum but it looks like that is all I'm gonna get.
That removed any question of the quality rebuild and restoration performed by Sean Murphy http://smicarburetor.com/.
I also worked on my Bowtie Overdrives 2004R transmission http://www.bowtieoverdrives.com/cata....php?ITEMID=13 I installed a Art Carr performance TH 2004R Deep aluminum pan with a 700R4 filter as encouraged by various transmission builders such as, http://www.drwtransmission.com/thm_200-4r.htm.
That turned out AOk!
Today was a good day.
Kurt
383CID Lives
camsdad is offline
