New ZZ4 Rockers Noisey????? - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 11th, 08, 09:40 AM Thread Starter
TC
I got my new ZZ Fastburn running and the valvetrain seems noisey. Is this normal or are the valves loose and need adjusted? It's amazing withgood exhaust how quiet everything is, but the valvetrain is noisey as heck.
1968 Camaro RS orig AC car, ZZ Fatburn, Doug's D368 Headers, Tremec TKO600 w/ Hurst Blackjack, 12 Bolt Posi 3:73 mulitleaf, SFC's, Budniks, Hotchkis, Magnaflow, etc
6Z8RS is offline
post #2 of 8 (permalink) Old Aug 11th, 08, 11:09 AM
Re: New ZZ4 Rockers Noisey?????
I would run the valves soon. I presume this was a complete motor?
TC # 349
zdld17 is offline
post #3 of 8 (permalink) Old Aug 11th, 08, 11:27 AM
I had a zz3 which was the same way. - used to just take the valve covers off and adjust em with it running. Took just a few minutes..
68 SS 357, AFR195, Hotchkis, TKO600, 3:73
Miikeremains is offline
post #4 of 8 (permalink) Old Aug 11th, 08, 10:24 PM
madmax87's Avatar
I've read somewhere that these engines are just inherent to run noisy. I've just learned to live with it.
madmax87 is offline
post #5 of 8 (permalink) Old Aug 11th, 08, 10:38 PM
Doug
My zz4 with fastburn heads is quiet. Odd that yours is noisey.
Dougs72Nova is offline
post #6 of 8 (permalink) Old Aug 12th, 08, 06:04 AM
Jerome
I was told by Scott at Gilbert Chevrolet ,that these cam's are noisy ,I have a GM roller 542 /558 234/242 @.050 in my ZZ4 ,and it is noisy the bigger the noisier as he told me ,I called him twice and he said no worry (hope he right)…Happy motoring
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #7 of 8 (permalink) Old Aug 13th, 08, 01:02 AM
Terry
What's happening , especially with anything over .525 lift , is the dogbone shaped retainer is actually lifting slightly off the block and coming back down causing a ticking sound , plus the metal "spider" amplifies the sound like a drum ! I had a ZZ383 that did this , also the 1.6 aluminum GM rockers are inheirently noisy , kind of a mechanical noise , if you will .
Terry
Camaro :
Chevy II :
Too bad stupidity isn't painfull !
cheby2 is offline
post #8 of 8 (permalink) Old Aug 13th, 08, 09:28 AM Thread Starter
TC
Thanks everyone. I will check the valves in a few hundred miles, but it sounds like cheby 2 has a good answer. IT sounds like all of the rockers and not just one or two. It is a consistent sounds. I mainly wanted to hear if the ZZ motors normally came with loose rockers or if this is the case of a common mechanical noise.
6Z8RS is offline
