vacuum canister with how much cam - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 11th, 08, 06:02 PM Thread Starter
hp fan
Hi Guys,
How much camshaft are guys able to get away with before you find you need an extra vacuum canister to assist the factory power booster?
I will be using a dual plane intake which will give better vacuum anyway.
hp fan is offline
post #2 of 4 (permalink) Old Aug 11th, 08, 07:24 PM
Shawn
Re: vacuum canister with how much cam
i have a 280h cc cam in my 302 ([email protected] and .480 lift) with a single plane intake that was giving me 10" at idle this is with stock 462 heads small valve, and bad rings
victimizati0n is offline
post #3 of 4 (permalink) Old Aug 12th, 08, 03:14 PM
Steps
It works, in practice like this with low idle vaccuum
u approach an interesection, load on engine brake, hi vac , constant brake use, stop, foot tends to ret on brake while stopped...if u remove replace a couple times, the brake works just hard, but it is very rare u will do this...so an non issue
The only place u will notice is if idle out of a gas station, slow cause a car is in front, they pull away, u stop (u havnt touched the throttle) pull forward slightly and stop for traffic, and the brake is hard...sometimes.
This tends to be when a idle vaccuum is about 6" and below...and u need a real wild track cam to get that....and a baddly adjusted carb (mixtures, idle, and sec butterflys way off) AND a dizzy curce way out of wack
Steptoe is offline
post #4 of 4 (permalink) Old Aug 12th, 08, 03:55 PM
Patrick
I noticed that I needed a can and got one with this cam in my sig. And It solved the problem.
I think you on the border of needing one. If you are having problems with your brakes getting hard now, get one. You won't be dissatisfied.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
