Battery charged, cables new but voltmeter reads 8 volts & no start - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 11th, 08, 07:08 PM Thread Starter
Brent
Brentmc's Avatar
Here is my issue.
The car started fine last week.
I went to start it tonight and the starter just goes "click, click, click, click, click". The voltmeter reads 8 volts so it would seem that it was simply a dead battery...I checked the battery and it has a full 14 volts. Cables on the battery end are shiny clean.
What could be my problem here?
1968 RS/SS Lemans Blue
Brentmc is offline
post #2 of 14 (permalink) Old Aug 11th, 08, 07:28 PM
Chad
67 Plum's Avatar
Re: Battery charged, cables new but voltmeter reads 8 volts & no start
Bad connection on the starter?
67 Plum is offline
post #3 of 14 (permalink) Old Aug 11th, 08, 07:51 PM Thread Starter
Brent
Brentmc's Avatar
It is curious that the battery is at 14v but the voltmeter reads 8v....what could it be...?
Brentmc is offline
post #4 of 14 (permalink) Old Aug 11th, 08, 08:00 PM
Brandon
Still sounds like a loose connection be it at the starter or at the horn relay.
Brandon J. licence 1NASTY67
Nantooch is offline
post #5 of 14 (permalink) Old Aug 11th, 08, 09:35 PM
Jeff
yellow69RS's Avatar
When I see those I go back to the basics. Clean battery cables at battery, pull the bolts out if it's side post. Clean comnections at starter and ground connection at block. Clean positive at horn relay and ground at fender. Inspect anything else that might remotely be suspect like fusable links etc. Another long shot is the connnections between the firewall connector. I've only been there a few times and I think mostly one brand/mode; of car. (not camaro)
Jeff
yellow69RS is online now
post #6 of 14 (permalink) Old Aug 11th, 08, 09:36 PM
Ya check the voltage at the horn relay, put a load on it too and check. Could be something silly like the wires came loose on the junction block behind the battery.
post #7 of 14 (permalink) Old Aug 11th, 08, 10:19 PM
"Tri-Tip"
Gary L's Avatar
It is reading a big voltage drop. Bad connections.
Gary L is offline
post #8 of 14 (permalink) Old Aug 12th, 08, 05:37 AM
Bob
Disregard.... I guess I should read the titles a little more carefully.
Maybe a rotted negative cable. I have seen them corrode between the battery and the engine and have the ends look fine. Feel along the neg. cable for a hot spot after trying to start the car.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #9 of 14 (permalink) Old Aug 12th, 08, 10:12 AM
Kyle
I'm betting you have a poor ground make sure your ground is at a non painted surface with no corrosion
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #10 of 14 (permalink) Old Aug 12th, 08, 10:46 AM Thread Starter
Brent
Brentmc's Avatar
Thanks all.
The big question was why the battery was fully charged at 14v but the voltmeter gauge reads 8 vlts. I will remove and clean both cables at both ends and retry tonight...
Brentmc is offline
post #11 of 14 (permalink) Old Aug 12th, 08, 10:51 AM
Fred
Another thing Brent, after a week of sitting without a draw, your fully charged battery should read about 12.6 volts, not 14.
Oh, another thing, 8 volts doesn't seem to be enough power to make a starter click. Hmmmm,,,,
128.79mph 1.428 60'
Fred Ficarra is offline
post #12 of 14 (permalink) Old Aug 12th, 08, 11:02 AM Thread Starter
Brent
Brentmc's Avatar
Fred,
Great catch. I think I was measuring the voltage after hooking it directly to the battery charger and then unsucessfully trying to start it...
Obviously not a good time to measure it...I checked it later and it had 12.6-ish volts...
Brentmc is offline
post #13 of 14 (permalink) Old Aug 12th, 08, 02:20 PM
"Tri-Tip"
Gary L's Avatar
I see no mention of how old the battery is. The last one I changed would lose enough charge to give the symptoms you have in a couple of days. A new battery and problem was solved. I was chasing mystery drains etc. Batteries just get tired after a few years. Especially if they don't get regular charging.
Gary L is offline
post #14 of 14 (permalink) Old Aug 12th, 08, 07:39 PM Thread Starter
Brent
Brentmc's Avatar
Follow-up:
Two things were wrong. Ground cable was dirty and battery was dead. Car couldn't be jump started because of ground. Once we cleaned the ground, measured the battery voltage (6.8 volts), charged the battery, it started right up.
Thanks guys for the guidance. Another problem solved.
Brentmc is offline
