Taller original factory looking valve covers - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 11th, 08, 09:38 PM Thread Starter
Has anyone tried these valve covers
http://www.ss396.com/mm5/merchant.mv...ERSACCESSORIES
l
click
I would like to try to have as much stock looking as I can. I have a 69 Camaro 396 with Crane 1.7 roller rockers and Comp cams 555/552 cam. It now has Edlebrock tall valve covers.
Do I need tall valve covers with the roller rockers?
THANKS RAYZZ MY CAMARO LIKES MY MONEY
Rayzz is offline
post #2 of 4 (permalink) Old Aug 11th, 08, 10:20 PM
Ron
Re: Taller original factory looking valve covers
Tall Valve Covers are only used if you running a Stud Girdle and 6500 rpm+. You might conceal the rouge of + RPM with a Shaft Rocker under a Stock Valve Cover.
Sorry but does this look stock:
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 4 (permalink) Old Aug 12th, 08, 05:46 AM
AJ
You may actually need tall valve covers with poly locks.
I know there was no way in hell I was getting stock height valve covers with poly locks in a small block.
Actually, they still rub on the sides with taller, fatter covers.
Pro mag type roller rockers are pretty big...
A person probably could not tell just by looking at it, they probably wouldn't even think about it.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #4 of 4 (permalink) Old Aug 12th, 08, 08:51 AM
Is there room for a tall cover on your Big Block at the Power Brake booster ?
TJS69 is offline
