Fuel Line Leak? - Team Camaro Tech
post #1 of 16 (permalink) Old Aug 12th, 08, 10:41 AM Thread Starter
Fuel Line Leak?
I have some fuel leaking out of a small rubber hose (maybe 6 inches long) in the back of the car by the gas tank. It looks like a hose that connects the tank to the fuel line to the front of the car.
My Question is, how do I replace it? If I unhook it, is fuel going to squirt out all over the place?
67 RS / SS 350 Coupe
heyatomicdave is offline
post #2 of 16 (permalink) Old Aug 12th, 08, 10:56 AM
Fred
Re: Fuel Line Leak?
It'll dribble. But be SURE to release the preasure in the tank by opening the gas cap. Use common sense and you'll be fine. But don't wait.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 16 (permalink) Old Aug 12th, 08, 11:38 AM
Jerome
Re: Fuel Line Leak?
unhook rubber line from the hard line running foward, put a 3/8 bolt in the rubber line ,connect new rubber line to hard line ,remove old rubber line from tank line connect new rubber line to tank line ,you will loose a little fuel but thats the way it goes...Happy motoring soon
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #4 of 16 (permalink) Old Aug 12th, 08, 04:53 PM
Banned
Ron
Badbird's Avatar
Re: Fuel Line Leak?
Don't crawl under there with a lit cigarette and don't use your Bic lighter as a flashlight, in case you can't see!.....Have a happy, gas free, motoring!
Badbird is offline
post #5 of 16 (permalink) Old Aug 12th, 08, 06:01 PM Thread Starter
Re: Fuel Line Leak?
Thanks for the info. As far as the part goes, this is what I want, right?
http://www.rickscamaros.com/product....dept%5Fid=3170
post #6 of 16 (permalink) Old Aug 12th, 08, 07:44 PM
Russ
Re: Fuel Line Leak?
Yes it is.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
19694speed is offline
post #7 of 16 (permalink) Old Aug 12th, 08, 08:10 PM
scblucam's Avatar
Re: Fuel Line Leak?
I replaced mine with braided stainless. Lasts forever.
scblucam is offline
post #8 of 16 (permalink) Old Aug 12th, 08, 08:45 PM
Jeff
yellow69RS's Avatar
Re: Fuel Line Leak?
AND don't use a 110 volt drop cord.....
Jeff
yellow69RS is offline
post #9 of 16 (permalink) Old Aug 13th, 08, 08:04 AM
Ted
Re: Fuel Line Leak?
Go to your local hardware store and get your fuel line. It won't cost that much.
tgifford5 is offline
post #10 of 16 (permalink) Old Aug 13th, 08, 06:59 PM
Re: Fuel Line Leak?
Jeff
This is very good advice. When I was a teen I pulled the fuel line on an old Duster. Fuel poured out and hit the drop light at my side. Luckily it only sizzled, but that was VERY close to a very bad situation. Be careful.
go2fast is offline
post #11 of 16 (permalink) Old Aug 13th, 08, 07:41 PM
Jeff
yellow69RS's Avatar
Re: Fuel Line Leak?
Two of my former employers forbid it. One from personal experience. He was doing work out of his garage at home in addition to his full time job at Monkey Wards. He was replacing an intank fuel pump and the fuel spilled all over and broke the bulb and started a fire in his attached garage. He was burnt very badly keeping it from burning down his house. His one ear looks like it's made from wax that has drooped slightly.
Jeff
post #12 of 16 (permalink) Old Aug 16th, 08, 12:52 PM Thread Starter
Re: Fuel Line Leak?
Well, it turns out it's not the line which looks like crap but is not leaking. There is a small crack in the tank right on the edge below the fuel line which looks as though it was repaired at some point with some type of rubber compound. I scraped all that off and I think I can fix it with some JB Weld.
I was thinking about getting out the hibachi and grilling some steaks under there while I work. Wish me luck!
post #13 of 16 (permalink) Old Aug 16th, 08, 01:12 PM
Banned
Ron
Badbird's Avatar
Re: Fuel Line Leak?
I'll take mine, medium rare, a little pink inside, NOT YOU, the steak!!.....I strongly suggest to purchase a new gas tank because all the rust in that tank will work it's way in the carburetor eventually!
Badbird is offline
post #14 of 16 (permalink) Old Aug 16th, 08, 01:39 PM Thread Starter
Re: Fuel Line Leak?
Probably good advice. What's the difficulty level on that one? Do you have to get all the gas out first?
post #15 of 16 (permalink) Old Aug 16th, 08, 01:47 PM
Re: Fuel Line Leak?
Difficulty level is maybe a 3.
Fuel line, sender ground wire, sender wire in the turnk, push it down thru the hole.
Crawl under feet first, take off 2 nuts at rear of straps, tank falls on your chest. Wiggle out from under the car with the tank on your chest.
It's (unfotuantely) always a good idea to get it apart before you buy stuff. Just to make sure you know what you need.
For sure you'll need the tank, the strap insulators, and the rubber hose and clamps, and the sender o-ring.
possibly to probably, you could need new sender, sender wiring, and straps.
