bent crank - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 12th, 08, 06:17 PM Thread Starter
Tony
Send a message via AIM to tony -Di
bent crank
is it possable that the end of the crank can be bent ??? if i watch as the engine is running the balancer is wobbleing i know its tight and it a fluid damper
tony -Di is offline
post #2 of 8 (permalink) Old Aug 12th, 08, 06:26 PM
Alan
Re: bent crank
More likely a bad damper. At least that is easier to replace than the crank!!!
alan
alanrw is offline
post #3 of 8 (permalink) Old Aug 12th, 08, 07:06 PM
Royce
Re: bent crank
Pull the damper off and set up a dial indicator on the crank snout. That is one way to tell for sure. I would suspect the damper but, it very well could be the crank snout. If the snout itself were bent I would suspect your timing cover seal to be leaking and/or damaged. How much movement are we talking?
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #4 of 8 (permalink) Old Aug 13th, 08, 07:10 AM
Re: bent crank
I have seen a motor with the same condition you described that had a broken crank and still ran. It could be broken.
1968 Camaro Ragtop 4 speed
Chilli is offline
post #5 of 8 (permalink) Old Aug 13th, 08, 07:54 AM
Harley
wiskeesour's Avatar
Re: bent crank
ive seen the crank bolt cross-threaded...
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #6 of 8 (permalink) Old Aug 13th, 08, 10:55 AM
Fred
Re: bent crank
I've cross threaded crank bolts. Don't ask.
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 8 (permalink) Old Aug 13th, 08, 11:38 AM
Banned
Ron
Badbird's Avatar
Re: bent crank
Are you sure it's the balancer??.....I suspect either a bent, warped or out of round crank pulley!
Badbird is offline
post #8 of 8 (permalink) Old Aug 13th, 08, 12:53 PM
Ron
Re: bent crank
I bought a New 72 Challenger 340 MAG RS and drove it across the street and pulled the engine. Of course I voided my warranty right there - LOL Any way my job required, I do a lot of driving and I wanted something more. In the process of the motor tare down to install a Crane Cam, heads with Larger Valves and employ the infamous SB Dodge Oil Gallery Mod, I came across 2 cross threaded Connecting Rod Bolts, right from Chrysler.
This was my 70 1/2 Z28
Z15CAM is offline
