Doug's D368 Headers - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 12th, 08, 09:52 PM Thread Starter
Andy
Send a message via AIM to 67SS&99SS
Doug's D368 Headers
Do any of you guys have this header on your Camaro? If you do what is your engine mount/frame stand combination and how is the fitment? I have searched site and found a few things about this header but not much. I have a brand new set of hooker super comp 2130HKR headers for my 406, but I was wondering if the dougs headers would be better for my application? I bought the hookers because I found them at a swap meet for $150 bucks(430 bucks everywhere online) and I knew they would fit with angle plug heads. However, they are the smaller primary, 1 5/8". I am going to run angle plug AFR 195 eliminator heads on a 406.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #2 of 12 (permalink) Old Aug 13th, 08, 06:11 AM
Smile Re: Doug's D368 Headers
I have D-368's on my '69. They fit fine. Because my motor has raised port exhaust ports I had to slot the flanges. This raises the headers about 1/4 inch in relationship to everything else but I have no fitment problems.
The idlers arm is close and the left upper c/arm bolt is close but everything clears. With the angle plug heads the plugs are easy to get to. Lots of room for the bell crank.
They do fit snug under the car. Ground clearance is great!
They do sound just a little bit tinny.
I'm happy. I did my research when I replaced my motor mounts.
All is good.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #3 of 12 (permalink) Old Aug 13th, 08, 06:55 AM
I'd stick with the Hooker headers. A properly designed set of 1-5/8" headers will work just fine on your car.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #4 of 12 (permalink) Old Aug 13th, 08, 01:20 PM
6D9
Ron
how high are you going to twist it??
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #5 of 12 (permalink) Old Aug 13th, 08, 06:09 PM Thread Starter
Andy
6500 probably, really it depends on what the dyno says. I carried my block to the machine shop last week, he's doing the machine work this week and the assembly probably next week. I'm going to have him dyno the motor when he is finished so I'll know where the peak #s are. I'm expecting this to be a 500-540 hp motor.
post #6 of 12 (permalink) Old Aug 13th, 08, 06:11 PM Thread Starter
Andy
All is good.
Do you have any pictures of yours?
post #7 of 12 (permalink) Old Aug 14th, 08, 05:18 PM Thread Starter
Andy
I guess I will get the dougs headers. The engine builder said that I would dyno a good bit higher with the 1 3/4" and they would better suit my build than the 1 5/8". He said that the 1 5/8" would be perfect for a similarly built 350.
post #8 of 12 (permalink) Old Aug 14th, 08, 05:52 PM
I have a set of TriY on my AFR 195 heads, not the new ones. They fit well , match ports but if I had the option, I would go for the 1¾ 4 into 1 tubes. I use the stock sbc towers that came with my car . I suspect the small tubes, 1 5/8", could be holding back some hi end hp but then again, I don't hi end the motor, every day or weekend. Mainly a long distance hi speed cruiser.
TC # 349
zdld17 is offline
post #9 of 12 (permalink) Old Aug 22nd, 08, 08:18 PM Thread Starter
Andy
Got to see the headers for the first time today. Got them on wednesday but I just started back at college and couldn't come back home til today. Nice heavy gauge tubing and thick flanges. Should look and perform well on the new motor. Engine builder said I would have it back the week after labor day. Here are some pics of the headers
post #10 of 12 (permalink) Old Aug 22nd, 08, 09:24 PM
Jack
I have those headers and they fit great. I think you said angle plug heads?? You will need shorty plugs in #3 and 5 I think. To install the drivers side just get the car up high to put in in from the bottom, header almost needs to be 90 degrees to the bottom of the car but it will slip right in. Passenger goes in from top. Took me no more than 20 minutes last time.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #11 of 12 (permalink) Old Aug 22nd, 08, 09:51 PM
Sorry, I just saw your reply. I don't have pictures as my camera only takes blurry pictures. I should get a cheaper one next time.
I layed my left side header in place and tied it up with bungy cords when I put my motor in. I only put 2 bolts in each side. And later installed the header gaskets. I put the right side in after I had the motor bolted down and the starter in. I have that much room!
Plug clearance is no problem with std. length plugs on all cylinders.
__________
post #12 of 12 (permalink) Old Aug 23rd, 08, 04:43 PM Thread Starter
Andy
Yes I have angle plug heads. Thanks for the tips.
