Oil pressure guage line - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 13th, 08, 09:01 AM Thread Starter
Ron
I just installed my guages for 67 RS console package and could not find where the oil sending line went so instead of looking through manuals or even asking here I went and drilled a new hole. Now of course when I started running it through and going to hook it up I find the original hole behind the distributor. There does not seem to be a way to run the hose through there without taking apart the heater duct (again), but maybe I can snake it through.
My question to you guys is; would you leave it where it is or run it through the original hole?
Looking forward to all your input. The car will be a driver and is not being restored to show quality if this helps.
rjg67rs is offline
post #2 of 9 (permalink) Old Aug 13th, 08, 01:09 PM
Re: Oil pressure guage line
For me , on a 69, there was a small indention just above the speedo grommet. I drilled it to allow a rubber grommet to prevent line chaffing , and ran copper line, the good stuff. I later enlarged the same hole to run steel braded line. Might work for you on a driver.
TC # 349
zdld17 is offline
post #3 of 9 (permalink) Old Aug 13th, 08, 03:52 PM
Ron
I mount a Brass or Hi-Pressure Coupler through the FireWall and run a Hydraulic Hose in the Engine Compartment and the Lighter Nylon one under the Dash to the Gauge.
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 9 (permalink) Old Aug 13th, 08, 06:14 PM
Charlie
If you already have the new hole drilled, use it. You can always use the original hole for something else if you ever need to run something behind the dash.
67CamaroRS/SS is offline
post #5 of 9 (permalink) Old Aug 14th, 08, 01:15 PM Thread Starter
Ron
I think I'll leave it at the hole I drilled, I also like Z15CAM's idea. Thanks for all your input.
rjg67rs is offline
post #6 of 9 (permalink) Old Aug 14th, 08, 05:14 PM
Called a bulk head fitting, Good idea, better than mine.
TC # 349
zdld17 is offline
post #7 of 9 (permalink) Old Aug 23rd, 08, 10:51 PM
I used a copper line on my old dual 4's 327 and found that the copper will vibrate and work harden, then finally break after a short time. get and use a pressure hose, or braided line for your oil guage. Good insurance!
warren bushing is offline
post #8 of 9 (permalink) Old Aug 23rd, 08, 11:03 PM
PA Camaro Guy's Avatar
Mine has good quality copper line running to the original port and then through the firewall to my gage cluster, which is fixed under the ash tray. Probably not where you have yours, but my three guage cluster (horizontal layout) looks good there and does the job, plus it was easy.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #9 of 9 (permalink) Old Aug 24th, 08, 06:49 AM
Kevin
Where can I find these braided lines at? And a bulkhead fitting?
kcart55 is offline
