Flowmaster exhaust hangers - Team Camaro Tech
post #1 of 19 (permalink) Old Aug 13th, 08, 04:40 PM Thread Starter
JcGc's Avatar
Well after several weeks of going back and forth on an exhaust system, I broke down and bought Flowmaster 17129 kit from summit. Now, I have no idea how the rear hangers go on the frame. Can someone with this kit please post up some pictures of where the rear hangers go. I know the instructions mention two holes in the frame, but the brackets they sent me do not line up with the holes.
Thanks in Advance!!!!!!!
1969 Camaro
JcGc is offline
post #2 of 19 (permalink) Old Aug 13th, 08, 07:17 PM
rick
Re: Flowmaster exhaust hangers
i think that is the same kit i installed on my 69 should be 4 brackets 2 install left and right inside the wheel well on the flat plates and the other 2 left and right bolt up to the floor pan just in back of the rear axel. mine fit very well and was an easy install
bikesnbroadheads is offline
post #3 of 19 (permalink) Old Aug 13th, 08, 07:40 PM Thread Starter
JcGc's Avatar
I had no problem mounting the hangers on the floor pan area. The problem I'm having is in the rear hangers. Do you have a picture of your install?
1969 Camaro
JcGc is offline
post #4 of 19 (permalink) Old Aug 13th, 08, 07:57 PM
Here's one of mine.
It's been a number of years since I put this system on the first time, but I do not recall the tailpipe brackets lining up with any existing holes. I recall they included self tapping screws, and the last thing you do when the system is on, tight, and aligned is drill the holes and zap in the screws.
post #5 of 19 (permalink) Old Aug 13th, 08, 08:19 PM Thread Starter
JcGc's Avatar
Thanks for the picture Jim!!!! The hangers that came in my kit look nothing like the pictured one. These are square, and the isolator mount is turned out towards the tire.
1969 Camaro
JcGc is offline
post #6 of 19 (permalink) Old Aug 13th, 08, 09:06 PM Thread Starter
JcGc's Avatar
Here are the brackets that were sent in my kit.
1969 Camaro
JcGc is offline
post #7 of 19 (permalink) Old Aug 14th, 08, 09:38 AM Thread Starter
JcGc's Avatar
I know someone has this kit on their car.
1969 Camaro
JcGc is offline
post #8 of 19 (permalink) Old Aug 14th, 08, 10:28 AM Thread Starter
JcGc's Avatar
Well I called Flowmaster today. Very, Very good technical support. I was told the bracket mounts to the frame rail just like it's suppose to and the "L" or isolator mount goes towards the tire. Hope this works.
1969 Camaro
JcGc is offline
post #9 of 19 (permalink) Old Aug 14th, 08, 11:48 AM
Originally Posted by JimM View Post
Here's one of mine.
Rubber insulators I recieved with my 17104 kit are like Jim's but without the top hanger, instructions were to drill hole into box frame and use long bolt to hang the insulator, then insulator to hanger rod on pipe.
TC # 349
zdld17 is offline
post #10 of 19 (permalink) Old Aug 14th, 08, 12:23 PM
my exhaust hangers look just like the ones you have pictured. and i dont remember having to drill any holes. i can get a picture for you tonight if you would like.
68bigblockSS is offline
post #11 of 19 (permalink) Old Aug 14th, 08, 12:31 PM Thread Starter
JcGc's Avatar
68bigblockSS, A picture would be great!!!!! Thank you!!!!!
1969 Camaro
JcGc is offline
post #12 of 19 (permalink) Old Aug 14th, 08, 06:55 PM
Kevin
Here is a shot of the drivers side, hope it helps.
[U]1969 cloneish Z28
350,9.6 comp,Vortec heads,Crane 274ho6,rpm air gap,Flowmaster
HEI,Holley 600 DP,4 speed 3.11 first,Hotchkis suspension,3.08 rear... need posi.
hpcam is offline
post #13 of 19 (permalink) Old Aug 14th, 08, 07:19 PM Thread Starter
JcGc's Avatar
hpcam,
That helps alot, thank you. Do you have the flowmaster 17129 kit?
1969 Camaro
JcGc is offline
post #14 of 19 (permalink) Old Aug 15th, 08, 06:46 AM
Kevin
yep, thats the one.
hpcam is offline
post #15 of 19 (permalink) Old Aug 21st, 08, 10:17 AM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
How much room do you have between the isolator and your rims and tires?
-Doug
68 RS/SS Conv
67 Coupe
thedugan is offline
