Lost fuel pump - what damage done? - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 13th, 08, 08:38 PM Thread Starter
Ted
On my way to pick up my son from football practice my 69 died on me just as I pulled into the school parking lot. What happened as I see it is that the 2 bolts that hold the fuel pump on had worked their way out. It is just kind of hanging there. So I guess what my question is what damage if any might have happened? Do you think the fuel pump rod might have gotten bent? Any damage to the cam? The motor cranks over fine. That's what made me think I wasn't getting any fuel, when I noticed the pump kind of cocked out of the opening.
tgifford5 is offline
post #2 of 12 (permalink) Old Aug 13th, 08, 08:52 PM
Re: Lost fuel pump - what damage done?
I would guess everything is fine. I can't see the pump rod getting bent or the cam hurt. Bolt er back up in there and crank er over!
post #3 of 12 (permalink) Old Aug 13th, 08, 09:02 PM Thread Starter
Ted
That's what I was thinking, just wanted to make sure. Do you use Loctite thread sealer or anything to hold them in?
post #4 of 12 (permalink) Old Aug 13th, 08, 09:03 PM
Shawn
i agree, that pushrod is a pretty hefty hunk of metal
if anything the cam probably pushed the rod up and it stuck there
victimizati0n is offline
post #5 of 12 (permalink) Old Aug 13th, 08, 09:13 PM Thread Starter
Ted
What's the bolt size?
post #6 of 12 (permalink) Old Aug 13th, 08, 09:35 PM
Shawn
top or bottom bolts?
post #7 of 12 (permalink) Old Aug 14th, 08, 06:51 AM
Those bolts shoud be special hardened steel bolts. I had to purchase a pump and bolts for mine. Someone had instaled an electric fuel pump, and had used a block off plate.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #8 of 12 (permalink) Old Aug 14th, 08, 06:58 AM
The bolts that hold the pump on are regular 3/8-16 bolts, nothing special. I'm surprised you didn't notice an oily mess appearing before your pump bolts had backed all the way out.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #9 of 12 (permalink) Old Aug 14th, 08, 12:25 PM
Kyle
yeah i would put money on the fact that you did no damage that push rod would just fall down and rest against the plate and the cam lobe would just have nothing to push against... i can't even see how that would incurr and damage whatsoever unless you managed to drain your engine of oil through the gaping hole in your block where the pump used to be.. but so little oil makes its way in there you would probably have to drive a hell of a long way for that to happen
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #10 of 12 (permalink) Old Aug 14th, 08, 01:17 PM
Banned
Ron
Badbird's Avatar
I'm a little concerned as to how/why those 2 bolts "worked their way out"!!??.....I believe we're dealing with a couple stripped bolt holes!.....How could these 2 bolts, just suddenly, loosen up?....This would have to be a slow process, over time, and you should have been able to notice a drop in fuel pressure and also oil leakage!
Badbird is offline
post #11 of 12 (permalink) Old Aug 14th, 08, 01:40 PM Thread Starter
Ted
I would not be able to notice a drop in fuel pressure since I do not have a fuel pressure guage. As far as oil leakage everything would have been blocked off until the pump fell forward once the last bolt fell out. But I am going to check and see about the possible stripped holes. I believe that it could have loosened over time. How many of us look down at the pump and check to see if the bolts have loosened up? It is kind of down and out of mind.
post #12 of 12 (permalink) Old Aug 14th, 08, 02:05 PM
Banned
Ron
Badbird's Avatar
Just fell out!!....This is just mind boggling!!
Badbird is offline
