Big block motor mount offset - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 14th, 08, 02:12 PM Thread Starter
Going to be putting a 454 in my 69 Camaro soon and I am going to buy some new motor mounts. I am going to buy the big block frame mounts and the engine mounts. Question I have is which of the two mounts (frame or engine) actually makes the off set towards the passenger side?
Thanks in advance
hypersport750 is offline
post #2 of 8 (permalink) Old Aug 14th, 08, 02:14 PM
Re: Big block motor mount offset
frame. Driver side is taller than the passenger side.
Eric
Eric Kammerer is offline
post #3 of 8 (permalink) Old Aug 14th, 08, 02:18 PM Thread Starter
Thanks Eric, so I definetly need to buy the frame mounts, But I can upgrade the engine mounts such as a Lakewood set? should give me the same results of offset?
post #4 of 8 (permalink) Old Aug 14th, 08, 06:54 PM
PLEASE try to buy NOS frame and BB rubber SIZED mounts here b/c you need to do your homework and make sure what you buy fit's right!!
pdq67
post #5 of 8 (permalink) Old Aug 14th, 08, 09:12 PM Thread Starter
pdq67
Ok, but most NOS stuff is pretty over priced. Does th repop stuff come close?
post #6 of 8 (permalink) Old Aug 15th, 08, 05:49 AM
I purchased my reproduction BB engine frame mounts from Classic Industries and experienced no fitment issues. Although some will recommend Rick's First Generation Camaro as properly fitting as well. Either of these parts distributors is an excellent source.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #7 of 8 (permalink) Old Aug 15th, 08, 09:17 AM Thread Starter
Thanks David for the advice.
post #8 of 8 (permalink) Old Aug 15th, 08, 06:47 PM
You're welcome Rob
Turbo 400
