REALLY finding TDC??? - Team Camaro Tech
post #1 of 15 (permalink) Old Aug 14th, 08, 11:24 PM Thread Starter
I've been doing different things with my recent build to help teach myself things I need to know (with your help). I have, to date, always installed my cams straight up. I though that it would be fun to put my dial indicator on my motor before I slapped the heads on to find TDC other than on my balancer. I was suprised to find that there seems to be a breaking over point where the rod goes from being almost all the way up to just starting down and my dial indicator didn't move. In other words, it seems that I could move my motor over just slightly and not move the dial. If that's the case, how in the heck to you really determine TDC???? Thanks!
dubs68camaro is offline
post #2 of 15 (permalink) Old Aug 15th, 08, 12:01 AM
Steps
Re: REALLY finding TDC???
mark the piont where it stops and then the piont where it starts
then find the 1/2 way between..Damn near as, close as u will get TDC
be carefull
The cam turns 2x to the crank, so make sure that the crank is on the fireing stroke and not 180 degs out
Steptoe is offline
post #3 of 15 (permalink) Old Aug 15th, 08, 12:27 AM
Here's a pictorial:
http://www.fourwheeler.com/howto/67578/photo_01.html
Click on the other pictures for the remaining steps.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #4 of 15 (permalink) Old Aug 15th, 08, 03:03 AM
use a piston stop to find the actual true TDC.
without the heads on, bolt a piece of angle iron with a bolt in the middle across the top of the cylinder so the piston will hit it as it comes up.
gently crank the motor over one way until it hits the stop- and mark the balancer or write down the number on the degree wheel.
then, turn it the other way until it hits the stop, and mark the balancer or write down the number.
true TDC is exactly halfway between these two marks.
if the heads are installed, you do the same thing but with a stop screwed into the #1 spark plug hole.
you don't plan sincerity.
novaderrik is offline
post #5 of 15 (permalink) Old Aug 15th, 08, 08:46 AM
Originally Posted by novaderrik View Post
use A Piston Stop To Find The Actual True Tdc.
Without The Heads On, Bolt A Piece Of Angle Iron With A Bolt In The Middle Across The Top Of The Cylinder So The Piston Will Hit It As It Comes Up.
Gently Crank The Motor Over One Way Until It Hits The Stop- And Mark The Balancer Or Write Down The Number On The Degree Wheel.
Then, Turn It The Other Way Until It Hits The Stop, And Mark The Balancer Or Write Down The Number.
True Tdc Is Exactly Halfway Between These Two Marks.
If The Heads Are Installed, You Do The Same Thing But With A Stop Screwed Into The #1 Spark Plug Hole.
+1^
67 Bassman is offline
post #6 of 15 (permalink) Old Aug 15th, 08, 08:55 AM
Ed
BigBlock1969RS's Avatar
+1 to the above for using Timing Wheel and Piston stop, zero timing wheel, using piston stop.
Ed
BigBlock1969RS is offline
post #7 of 15 (permalink) Old Aug 15th, 08, 03:00 PM
Den
DenRS's Avatar
I'll 2nd the using the piston stop and degree wheel. I highly recommend using comp cams crank socket so you can easily move your degree wheel. Its not necessary, but it sure makes life easier.
http://www.jegs.com/p/Comp+Cams/753185/10002/-1/10783
DenRS is offline
post #8 of 15 (permalink) Old Aug 15th, 08, 03:40 PM
Tim
77wolf10.85's Avatar
You can do it with your dial indicator, halfway inbetween any dimension down coming upwards from both directions. That sounds wierd, what it mean is to have the piston coming up each time you stop at say .050" before Zero on the indicator. The opposite of this would be .050 on the down stroke, and you would get some pin slop and piston slop in your reading.
BTW that dwell time you discovered at TDC is the reason they play with rod lengths. Altering rod length alters how long the piston is at TDC and thereby changes the crank angle when the power stroke begins.
Tim Smith
77wolf10.85 is offline
post #9 of 15 (permalink) Old Aug 15th, 08, 11:21 PM Thread Starter
If this is a secret power trick Tim, please switch to stealth mode when giving me this info!!! LOL
post #10 of 15 (permalink) Old Aug 16th, 08, 08:04 AM
The piston is at TDC exactly the same amount of time regardless of the length of the rod.
post #11 of 15 (permalink) Old Aug 16th, 08, 03:23 PM
I used a micrometer dial indicator to find TDC on my 454. True TDC for mine was actually 4 degreees ADV on the factory indicator. I use 4 degrees as "my zero".
74LS454 is offline
post #12 of 15 (permalink) Old Aug 16th, 08, 03:38 PM
Larry
I disagree. The difference is minimal, but it does exist.
Fathom Green 69 DZ x77 Done soon if the Mastercard holds out!
ldrisner is offline
post #13 of 15 (permalink) Old Aug 16th, 08, 04:13 PM
When is the piston at TDC? Is it at TDC 0.001 BTDC? Is it at TDC 0.001 ATDC? TDC means top dead center, not somewhere around the top of the stroke. The length of the connecting rod will slightly affect the rate at which the piston approaches and leaves TDC, but TDC equals TDC for any rod.
At the same crank angle in a standard 350 SBC, how many degrees from TDC will a 5.7" rod be 0.001" deeper in the cylinder than a 6" rod?
2? 5? 7? 10? 15? >15?
post #14 of 15 (permalink) Old Aug 16th, 08, 04:52 PM
Tim
yeah I misspoke. It is at TDC the same time, it's the arc to the sides that alters.
Tim Smith
post #15 of 15 (permalink) Old Aug 16th, 08, 05:24 PM
Tim
The arc to the side before the piston moves, I should say.
Tim Smith
