engine idle - Team Camaro Tech
post #1 of 22 (permalink) Old Aug 15th, 08, 01:44 PM Thread Starter
Cruzin "the 82"
angelglo's Avatar
engine idle
ive got a 350 with a quadrajet. it idles at about 1000 rpms which seems to be on the high side. i adjusted the idle screw all the way down as to not contact thte stop anymore. first, what should i be ildeing at? the cam is a very mild cam. how can i adjust to bring the idle down? i dont have an exact timing. if i retard the timing anymore, it startes to backfire out of the carb.
angel
angelglo is offline
post #2 of 22 (permalink) Old Aug 15th, 08, 01:47 PM
AJ
Re: engine idle
Check for vacuum leaks.
Also it does not take much movement at all to retard the timing a few degrees and drop the idle speed.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #3 of 22 (permalink) Old Aug 15th, 08, 02:07 PM
Re: engine idle
make sure the secondaries are closed all the way. had a carb where the secondaries were a bit sticky and wouldn't close all the way, couldn't idle below 1200 with the idle adjustment backed all the way out. a good dose of carb cleaner and worked the secondaries back and forth, problem solved.
Aaron67 is offline
post #4 of 22 (permalink) Old Aug 15th, 08, 02:58 PM
Re: engine idle
Make sure she's not on the fast idle cam, it's on the pass side of the carb.
post #5 of 22 (permalink) Old Aug 15th, 08, 04:34 PM
Charlie
Re: engine idle
Did you make sure the engine was warmed up completely before making the adjustments? The choke needs to be in the verticle position. That way it's not idling on the fast idle(choke setting).
67CamaroRS/SS is offline
post #6 of 22 (permalink) Old Aug 15th, 08, 06:04 PM
Steven
Re: engine idle
You probably need to advance the timing, then back off the idle adjustment screw ... Assuming you have a vacuum advance, you will need to pull and plug the vacuum line to initially set your timing. Afterwards, particularly if you are using full time vacuum, you will need to back off the idle speed after reconnecting time vac adv.
sdtsdt is offline
post #7 of 22 (permalink) Old Aug 17th, 08, 07:07 PM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: engine idle
john, i tried to retard the timing. when i do that just even a smidge, it starts to get bad response and back fires out of carb. i cant find any vac. leaks.
arron, the secondaries are closed all the way. its a freshly rebuilt carb.
charlie, i have it completely warmed up. i tried to do the adjustments affter i would go on a test drive.
i havent really tried to apply to much advance. i will try to do that on my next tuning session.
thanks guys.
angel
angelglo is offline
post #8 of 22 (permalink) Old Aug 17th, 08, 07:11 PM
Skip
Skeeter55's Avatar
Re: engine idle
Did you pull the dizz (180* off). Also have you check the dizz to make sure its not off a tooth. Finally is the vacuum advance working.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #9 of 22 (permalink) Old Aug 17th, 08, 08:17 PM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: engine idle
skip, are you talking about the distributor? its not 180 as it starts and runs fine. just idles a bit high at about 1000 rpms.
angel
angelglo is offline
post #10 of 22 (permalink) Old Aug 17th, 08, 08:23 PM
Skip
Skeeter55's Avatar
Re: engine idle
Ok then have you hooked up a vacuum gauge up to it, maybe the advance plate is stuck. If you unplug the vacuum advance hose will th idle drop.
post #11 of 22 (permalink) Old Aug 18th, 08, 04:29 AM
Re: engine idle
You have a vacuum leak somewhere or the throttle plates are sticking open, push linkage with finger?
A stock SBC w/Q-jet should be able to idle down to 450 rpm, barely turn over, and pull 18"-20" of vacuum. Lots of good suggestions here. Tighten intake bolts, check hoses or disconnect them and plug the nipple(s), check fast idle cam has fallen out of the way, trans linkage, if automatic, is not binding?
post #12 of 22 (permalink) Old Aug 18th, 08, 05:42 AM
Jeff
Re: engine idle
Also if you have power brakes make sure the diaphram in the booster isn't leaking vacuum. Either vacuum test it or plug the carb port to see if it makes a difference.
JZ
viperjesse is offline
post #13 of 22 (permalink) Old Aug 18th, 08, 06:09 AM
Re: engine idle
I wonder if the linkage from the pedal is holding it up?
blue ss is offline
post #14 of 22 (permalink) Old Aug 18th, 08, 03:36 PM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: engine idle
blue, linkage is not being held up.
skip, everett, and jeff, those are things that i havent done yet. i will pull the vac. advance hose and see if there is a drop. i will also try t pull the brake booster line and check that also. i also push the linkage all the way closed with finger and no change.
angel
angelglo is offline
post #15 of 22 (permalink) Old Aug 19th, 08, 06:17 AM
Re: engine idle
Maybe throttle shaft bushings worn and leaking? If you have a rich idle and now a vacume leak that could do it. Warped base plate? Mabe a lean idle and post nassel drip through main nozzle you can see it hit the base plate with a flsh light.. Just some thoughts
blue ss is offline
