should water be dripping from here????? - Team Camaro Tech
post #1 of 11 (permalink) Old Aug 17th, 08, 08:52 AM Thread Starter
Getting ready to fire my motor this morning. I'm filling up the cooling system with water. I decided to pour water through my manifold to make sure that the block is full when I fire. I noticed that water is trickling out a little hole at the bottom of the water pump, below the snout. I do know the hole is supposed to be there but should water come out it if I'm pouring water through the manifold??? I realize water is going down the bypass and directly into the pump. Is that it?? Thanks!
I'm excited. Nothing like that little knot in your tummy when you pull the trigger for the first time!!!!!!
dubs68camaro is offline
post #2 of 11 (permalink) Old Aug 17th, 08, 08:59 AM
Re: should water be dripping from here?????
That's a weep hole. If there is water coming out of it you have an internal seal leaking in your pump. You might see the leak clear up by rotating the pump to work the seal some.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 11 (permalink) Old Aug 17th, 08, 08:59 AM
Skip
Skeeter55's Avatar
No it shouldn't be leaking from there.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 11 (permalink) Old Aug 17th, 08, 09:00 AM
Dale
Send a message via AIM to Dale8346
You need a new water pump. Replace it.
Dale8346 is offline
post #5 of 11 (permalink) Old Aug 17th, 08, 09:16 AM
Mike, 69's rule
zuma's Avatar
If the water pump is new, start it, let it get up to running temp. It (the seal) might seat and stop...if not, change it out with a good quality replacement...good luck
(STAY THIRSTY, MY FRIENDS).
1969 Camaro
1990 IROCZ28 convertible (SOLD)
2004 Silverado Z71 4x4
2008 Pontiac G8 GT
GGSMU member
zuma is offline
post #6 of 11 (permalink) Old Aug 17th, 08, 09:38 AM Thread Starter
it is not new and it is shot......I think the brake clean had something to do with it!
post #7 of 11 (permalink) Old Aug 17th, 08, 12:00 PM
Mike, 69's rule
zuma's Avatar
when in doubt, change it out......
1969 Camaro
2008 Pontiac G8 GT
GGSMU member
zuma is offline
post #8 of 11 (permalink) Old Aug 17th, 08, 12:46 PM Thread Starter
The new one is already on!!!!
post #9 of 11 (permalink) Old Aug 17th, 08, 04:14 PM
Levi
exactly
.Bad75. is offline
post #10 of 11 (permalink) Old Aug 18th, 08, 06:06 AM
Kyle
yeah that hole is like an early warning system on those water pumps usually water will drip out of there when the water pump starts to wear out.
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #11 of 11 (permalink) Old Aug 18th, 08, 04:27 PM
Sh-t, Brake Clean isn't strong enough to bother anything anymore!!
If it was sprayed down w/ good old Methylene Chloride, then I'd agree it ate the seal up.
pdq67
