vortec temperature sensor 3/8" - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 17th, 08, 05:32 PM Thread Starter
I have done a search and have not found an answer yet. I just installed vortec heads on my 327. The coolant temperature sensor for the vortec's is 3/8" npt and the stock sensor for a car with gauges is a 1/2" npt. I saw in an old post standard parts numbers for original sensor TS-6 and smaller threads, TS-26. I went to the parts store and we looked it up and the TS-26 looks like it's for idiot lights and not guage.
We found some sensors that would thread in and had a workable wire connection but they all had really high resistance. Around 1500-3000 ohm's compared to the stock 380 ohms at 100F for the original.
Has anyone found a sensor that works successfully? I would like to keep the sensor in the head.
Murph
murph's 68 is offline
post #2 of 10 (permalink) Old Aug 17th, 08, 08:40 PM
Re: vortec temperature sensor 3/8"
get a gauge sensor for a mid 80's Chevy truck that has a temp gauge. or a Monte Carlo SS. or Camaro. or pretty much anything that has a temp gauge.
you don't plan sincerity.
novaderrik is offline
post #3 of 10 (permalink) Old Aug 17th, 08, 09:54 PM
T
When I moved to 305 heads, I had the same problem. I looked around a LOT and could not find a "drop-in" coolant sensor. Stock sensor is 72-82 ohms @220 degF with 1/2-14 NPT thread.
Closest I could find was the TS-76 sensor which is 3/8-18 NPT and 138-156 ohms @220 degF. Just look up the part for 81 camaro or firebird w/ 305. This will be kind of "close" to original, but the temperature gauge will always read low unless you adjust the resistor on the back of the gauge or do something else to shift the resistance.
I had posted some info on that (as well as the temp vs. resistance info for the stock bits) here:
https://www.camaros.net/forums/showthread.php?p=1024554
TMessick is offline
post #4 of 10 (permalink) Old Aug 18th, 08, 01:40 PM Thread Starter
Thanks for the info. The TS6051 has the wrong threads. I got the TS6641 and now wonder what the proper resistance will be needed to add to the gauge to get it to read correctly.
Murph
post #5 of 10 (permalink) Old Aug 20th, 08, 06:02 PM
Jeff
I had the same problem and had the larger sending unit cut down and rethreaded to fit in the head from a local machine shop.
https://www.camaros.net/forums/showth...ighlight=a69rs
White 69 RS 350/350HP
A69RS is offline
post #6 of 10 (permalink) Old Aug 21st, 08, 04:44 AM
The next best fix, keep the sending unit for the inst cluster, not the heads.
The best fix is to redrill & tap the head and keep the same unit.
Everett#2390 is online now
post #7 of 10 (permalink) Old Aug 21st, 08, 06:32 AM
erik
I had a similar problem when I installed the sensor for my Spal fan control since I used a sensor for a late model car but didn't want to run in the head and couldn't run in the intake because of cooler lines. Speedway Motors has an adaptor to intall a 3/8 to a 1/2 port just for cooling senors, http://www.speedwaymotors.com/p/7198...quot;-NPT.html
This is the one I used and it worked great since I couldn't get anything with the 3/8 npt locally
tumper is offline
post #8 of 10 (permalink) Old Mar 1st, 09, 05:51 PM
seeburg220's Avatar
That link above is dead. I think I found the part you were talking about, though:
http://www.speedwaymotors.com/Mechan...hort,7197.html
The above adaptor is "short". The one below is "long". Real descriptive!
http://www.speedwaymotors.com/Water-...apters,94.html
1969 / 350 / TH350 / 3.73 posi / driver
seeburg220 is offline
post #9 of 10 (permalink) Old Mar 5th, 09, 08:09 PM
seeburg220's Avatar
Well, I was wrong. I got the short fitting today and it's way too small, diameter-wise. There is no way the standard temp sender for gauges, will fit in it. Looks like I'm off to visit the machine shop to have them tap it down.
post #10 of 10 (permalink) Old Apr 7th, 09, 07:17 PM
seeburg220's Avatar
After having no luck finding a fitting to fit between the correct sensor and the head, I went to the dealer to see about one for an 80's Camaro with gauges...It was $75 ! So I passed on it, and went to Advance Auto and bought it for about $12. I still have the issue of it having the wrong resistance value, but perhaps this can be dealt with over time.
If you're adding Vortec heads to your engine, I highly recommend having the hole in the head tapped out for the original sending unit. Wish I would have thought of that first!
