Oil question: Just broke in cam and now.... - Team Camaro Tech
post #1 of 15 (permalink) Old Aug 18th, 08, 05:00 PM Thread Starter
I'm wondering if I need to change right away with conventional oil or can I switch to syn? In addition to a cam change, this thing also got new rings and a hone. Is it a good idea to run rotella for a set amount of miles to really let those rings seat in? They were cast rings which is what the machine shop recommended since it wasn't a fresh bore....rather just a clean up. He said that the cast are more forgiving and this is not a performance application. Thanks!
dubs68camaro is offline
post #2 of 15 (permalink) Old Aug 18th, 08, 05:12 PM
Patrick
Re: Oil question: Just broke in cam and now....
I would run the rotella just for good measure. It sure won't hurt anything.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #3 of 15 (permalink) Old Aug 18th, 08, 05:15 PM
Fred
Flat tappet or roller? Rotella for sure with a flat.
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 15 (permalink) Old Aug 18th, 08, 05:19 PM
Skip
Skeeter55's Avatar
OK now i want to here the beast....
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 15 (permalink) Old Aug 18th, 08, 05:43 PM Thread Starter
Have you ever built a motor for a specific vehicle and then wish you had something else it was going in?? That's where I'm at. I just got my "tow vehicle" 454 lit up yesterday and broke in. It sounds HHHHEEEAAAAALLLLLTTTTHHHHYYY!!!!! lol
I didn't think to video it and now all the stuff I had on it to fire is pulled back off. I realize that they sound more responsive on the test stand when they don't have the weight of a converter or flywheel to slow down the R's, but this thing revs real quick (keep in mind I'm talking at very low rpms). I'm wishing it was going in something else. I think this is a case where I didn't go too big in any one area and everything is matched up quite nice. Here is the skinny:
2 bolt 454 with steel crank (balanced)
781 heads
Crane 272H .515 lift cam (UD Harolds favorite for towing)
Performer 2.0 intake
Edelbrock 1411 750 carb
H.E.I. dizzy
1 3/4 long tube headers
post #6 of 15 (permalink) Old Aug 18th, 08, 06:41 PM
Nothing wrong with running Rotella , indefinately.
TC # 349
zdld17 is offline
post #7 of 15 (permalink) Old Aug 18th, 08, 07:46 PM Thread Starter
Do you think I should run any kind of an additive? I'm guessing that the EOS was just for break-in (man...that stuff is thick!)
The machine shop guy said to 15W40. My bearings are at about 2.5 on the plastigage
post #8 of 15 (permalink) Old Aug 18th, 08, 08:07 PM
george
Yes to running EOS with a flat tappet cam and no 02 sensors and cats.Todays oems all run roller trains that do not require the additives that protect old school lobes.I would stick with the dinosaur oil and additive until you retro to roller.I did go with Crowers cool face edm lifters for additional protection at low rpm.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #9 of 15 (permalink) Old Aug 18th, 08, 10:24 PM
Andy
Send a message via AIM to 67SS&99SS
I have to say, its good oil. I put it in my 340 that had been sitting for almost 30 years, and it worked like a charm. I put some marvel mystery oil in the cylinders first, let it sit for a week, then turned the engine with a flex handle and socket about 15-20 revs with all the plugs out. Put some new plugs in, and fired it right up. I just change it every 3 months or so. Its cheap, so why not? Best maintenance for an engine.
some good info. http://www.highperformancepontiac.co...comp_cams.html
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #10 of 15 (permalink) Old Aug 19th, 08, 11:44 AM
After reading everything on flat tappets I can find....I run Rotella and 8 ozs. of GM EOS.
74LS454 is offline
post #11 of 15 (permalink) Old Aug 19th, 08, 01:53 PM
Laurence
Lol_uk's Avatar
Eos is just for break-in...
I'm not convinced Rotella has the zinc you/I need for our engines (lots of boring research later!)...
http://www.zddplus.com/
Wouldn't run my engine without it. period.
..."you can never go fast enough"..driver,Two Lane Blacktop.
_____________________________________________
68 coupe/475ci/TH400/3.55 rear/Mark Jones motor: 850 Holley DP/Weiand stealth/9.2 comp/ Isky 280 mega cam/ 570+ hp/ 580+ Tq/brutal power!
Lol_uk is offline
post #12 of 15 (permalink) Old Aug 19th, 08, 09:31 PM
Shawn
yeah, put additives in there, i may be wrong, but from what i have heard newer engine oil doesnt have some of the additives needed for "older" style engines
i have heard to only use high mileage oil (like the 75,000+ mi oil) for the proper additives.. i may be wrong, and i hope someone can correct/agree with me
victimizati0n is offline
post #13 of 15 (permalink) Old Aug 19th, 08, 10:42 PM Thread Starter
Hey Victimization.......aren't you also over on the vintage mustang forum website????
post #14 of 15 (permalink) Old Aug 20th, 08, 07:10 AM
Shawn
nope, not me
post #15 of 15 (permalink) Old Aug 20th, 08, 07:28 AM
click's Avatar
Info. on flat tappet lubes and read 'recommendations' section closely about EOS. Synthetic info.
click is offline
