headers - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 19th, 08, 09:18 PM Thread Starter
steve
headers
What is the opinion on long headers compared to the shorty style. Not the block huggers but the 3/4 type I guess you could say. Not racing the car just tooling around town.
steve's 69ss is offline
post #2 of 5 (permalink) Old Aug 20th, 08, 10:33 AM
Matt
Re: headers
The longer the header the more low end torque you get. Short headers make more horsepower. The key is to get a set of headers that have equal length tubes and the correct pipe diameter for your application. Coatings are an additional choice, but keep in mind most coated off the shelf headers are coated only on the outside.
'68 Camaro SS. Dealer for American made performance & restoration parts.
Check my site
chassisboy is offline
post #3 of 5 (permalink) Old Aug 20th, 08, 10:42 AM
Andy
Send a message via AIM to 67SS&99SS
Re: headers
What size is your motor? How much hp do you predict it to make? A 1 5/8" primary longtube tuned length header is usually the best for most apps. Displacements over 400 C.I. with more than 450 hp, i would recommend a 1 3/4" header. Also, do your research to make sure you get the best fitting set of headers possible. You don't want to have to dimple a new set of headers for clearance. I just bought a set of doug's D368 headers for my car this week. I'll post some pictures when I go home this weekend. They are a little pricey but I've heard really good things about the fitment of these headers.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #4 of 5 (permalink) Old Aug 22nd, 08, 08:27 PM
Andy
Re: headers
https://www.camaros.net/forums/showth...80#post1051280 pictures are now in this thread.
post #5 of 5 (permalink) Old Aug 22nd, 08, 10:19 PM
Re: headers
Here's a thread where Rodney Davis of Headerdesign.com explains the difference between the two main types of headers.
https://www.camaros.net/forums/showthread.php?t=16596
So being very general, a low horsepower 350 CID V8 engine making only 1.5 horsepower per CID ( 525 hp ) may only require a primary tube size of 1 5/8"stepped to 1 ¾". This particular engine would only require a merged collector throat size of approximately 2 ¼" with a 3" outlet. The primary tube length is dictated by what RPM the engine is run at to obtain these power levels, with the vehicle weight, transmission, torque converter, and type of racing playing a dominating role.
Some good reading at http://www.perfweldheaders.com/techarticles.html
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
