pump fuel / running problems - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 21st, 08, 09:20 AM Thread Starter
WES
Hi
Has any one noticed that the cars are running alot worse on pump gas lately? I always run 100ll from the airport and the car runs great.Out pump gas in runs terrible. run on,lean,lack of power ay one else?? 427 stock 10 comp. Wes
WES 1967 yenko clone is offline
post #2 of 4 (permalink) Old Aug 21st, 08, 09:55 AM
Re: pump fuel / running problems
Yes, especially engines with carburetors. The oil companies are throwing all kinds of end oils and chemicals into the fuels lately, so they don't have problems disposing of them, and, they formulate the fuels for use in EFI systems, which don't require the better quality to perform acceptably. Fuels injected as a very fine fog-like mist, under extremely high pressure, react very differently than fuels inducted by vacuum pull signal, in raindrop sized droplets. What would seem a tuning disaster to a carb'd engine, is not even a hiccup in an EFI engine.
Regards,
Milton
The Devil's advocate is offline
post #3 of 4 (permalink) Old Aug 21st, 08, 10:11 AM Thread Starter
WES
Thanks , I thought i was losing it . can runs great put pump gas in runs like ****?
WES
post #4 of 4 (permalink) Old Aug 21st, 08, 06:43 PM
scblucam's Avatar
Gasoline basically does not exist anymore. It is toulene mixed with the evil ethanol corn mashings. It is so thin it boils over in carbed engines. Thank your government, the same one that refuses to drill for oil and thinks your car will soon be run by wind or solar power.
scblucam is offline
