What block? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 21st, 08, 10:25 AM Thread Starter
What block?
Never mind, sorry.
bnbpaintballer is offline
post #2 of 3 (permalink) Old Aug 21st, 08, 10:30 AM
click's Avatar
Re: What block?
ok
click is offline
post #3 of 3 (permalink) Old Aug 21st, 08, 10:32 AM
Robert
Re: What block?
A long block engine assembly usally includes the cylinder heads. Where as a short block does not. A short block will not have any lifters, push rods or rockers installed in it. If you are looking for a complete as possible engine you should be looking at a long block or crate engine assembly. If you want to build your own top end then a short block is the way to go. Most engine builders over a wide varitey of packages to choose from for your indiviual needs.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
68Holdon is offline
