diference between the L35 and the L34 - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 22nd, 08, 06:30 PM Thread Starter
Ben
Anybody know the diference between the L35 and the L34 block,I know the L35 had a two bolt main and cast crank, but where did the extra 25 horses come from on the L34?
Burntove
'69 Z28, '59 Apache pickup, '37 Hudson Terra plane '47 Hudson pickup, '46 Hudson Commodore.
'49 Harley pan, Previous vehicals; New '68 L-78 Chevelle, '69 Camaro SS-350, '69 chevelle SS, '70 Chevelle SS,'70 Camaro,'49 GMC, '65 Chevy C-10.
Burntove is offline
post #2 of 7 (permalink) Old Aug 22nd, 08, 06:34 PM
Banned
Ron
Badbird's Avatar
Re: diference between the L35 and the L34
The L34 had a hotter hydraulic cam with more duration.
Badbird is offline
post #3 of 7 (permalink) Old Aug 23rd, 08, 07:51 AM Thread Starter
Ben
Ok, I thought it had to be the cam or heads, thanks.
Burntove
Burntove is offline
post #4 of 7 (permalink) Old Aug 23rd, 08, 08:29 AM
L-34 = 350/360hp and has the 214/218, 115/???, .461"/.480" cam.
L-35 = 325 hp and has the 196/196, 113/???, .398"/.398" cam.
Otherwise, they are basically the same engine.
pdq67
post #5 of 7 (permalink) Old Aug 23rd, 08, 10:01 AM
Chad
67 Plum's Avatar
Didnt the L-35 have a Qjet and the L-34 360 hp. Chevelle engine have a Holley?
67 Plum is offline
post #6 of 7 (permalink) Old Aug 24th, 08, 07:38 AM
I think both engines started out w/ Holleys and later switched to Q-Jets. Probably not in the same years tho?
pdq67
post #7 of 7 (permalink) Old Aug 24th, 08, 08:52 AM
DjD
DjD's Avatar
In the Camaro there was no L34 in '67 and the L35 was equipped with a Q-jet. Block castings were 3902406 or 3916323. In '68 both were available, had Q-jets and block castings were 3916323 or 3935440. '69 was the same as '68 but with these block castings, 3935440 or 3955272 or 3969854. The L34 in the Camaro was rated 350hp in '68 and '69...
...Dennis
DjD is offline
