Leak from bolt on intake and oil pan - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 23rd, 08, 05:01 PM Thread Starter
Lifetime Gold Member
Drew
ddx77's Avatar
Hey guys, I was working on my car this afternoon and noticed a very small coolant leak from the most forward passenger side bolt that attaches my intake.
Can I just pull the bolt, throw a washer on it with a little loc-tite and re-intstall and not worry about it? Or is this an issue.
Here's a pic of the bolt: http://1969z28.com/intake.html
And in addition to my coolant leak it seems my oil pan has an oil leak from where the dipstick connects to the oil pan. Is this an easy fix or do I need a new oil pan as well?
Thanks again for your help!
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #2 of 3 (permalink) Old Aug 23rd, 08, 05:46 PM
Skip
Skeeter55's Avatar
Re: Leak from bolt on intake and oil pan
As far as the intake you could try, taking the bolt out and put some good permatex in the hole and then put the bolt in and tight back down, but it could get worse or better.
The dipstick has an O-Ring thats probably missing.
If its just the pan, you can clean the area with a good degreaser like even brake cleaner, then just mix up some J-B Weld.
Good luck.
Skip
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 3 (permalink) Old Aug 23rd, 08, 07:10 PM Thread Starter
Drew
ddx77's Avatar
Thanks Skip, appreciate it, i'll give it a shot!
ddx77 is offline
