350 cast dome pistons - Team Camaro Tech
post #1 of 16 (permalink) Old Aug 23rd, 08, 07:47 PM Thread Starter
I got a set of pistons and rods in on a trade today and the only markings I see on them are H102P near the pin and what looks like an S stamped on the other side of the pin. They look cast or HYPEREUTECTIC and have a dome on the top. The guy said the were a 350 040 over piston. Maybe a Sealed power or Sterling I think. Can anyone tell who makes these and what the spec's are?
Any help would be appreciated.
69z28302 is offline
post #2 of 16 (permalink) Old Aug 23rd, 08, 07:53 PM
Bill
Re: 350 cast dome pistons
They are Sealed Power and they are hypereutectic. Sealed Power and Sterling are the same thing.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 16 (permalink) Old Aug 23rd, 08, 10:15 PM
Steps
I and others here have had problems with sealed power mexican pistons (in the fine print)
inconsistant weights and casting /machineing
And buying off the net like that...all a set of pistons needs is the box to be dropped, doesnt take much to bend a skirt.
Steptoe is offline
post #4 of 16 (permalink) Old Aug 24th, 08, 01:36 AM Thread Starter
Bill , can you see if you can find the spec's for these pistons? I need to know if there for a 350 and the compression ratio. H102P
Thanks for you help.
69z28302 is offline
post #5 of 16 (permalink) Old Aug 24th, 08, 11:30 AM
Shawn
Originally Posted by 69z28302 View Post
Bill , can you see if you can find the spec's for these pistons? I need to know if there for a 350 and the compression ratio. H201P
well if it is an 040 piston it will not fit a 350
its more like a 358 or something around there
victimizati0n is offline
post #6 of 16 (permalink) Old Aug 24th, 08, 01:56 PM
Bill
Mike,
I will look in the Sealed Power catalog Monday morning. Might not post till the evening due to my dismal internet at the shop.
Personally I have had very good luck with Sealed Power's pistons. I was coplaining just the other day that a $600 set of "name brand" pistons varied almost 6 grams in a set, but I had a $70 set of Sealed Power ones ssitting on the shelf that were all within 1/2 gram. I would prefer to use them any day compared to KB's.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #7 of 16 (permalink) Old Aug 24th, 08, 05:11 PM Thread Starter
I know the pistons are 040 over. And I know that anything over a 4.000 inch bore increase the cubic inch's. I simpley got the pistons on a trade and was wanting to verify what the fit and the compression ratio with a 64 cc head. I don't plan on using them. I just need to know the spec's so I can tell anyone interested in buying them what they are. Sorry about that confusion
69z28302 is offline
post #8 of 16 (permalink) Old Aug 24th, 08, 05:30 PM
Tim
77wolf10.85's Avatar
H102CP comes up on FM's web catalog, but I can't find a 201.102 is like a .240 dome and 1.56 CD, 1/16 1/16th, 3/16 grooves. Lightweight coated skirt and CNC machined. Says it runs .001 clearance. wooo baby that's a long way from my 6 1/2
Tim Smith
77wolf10.85 is offline
post #9 of 16 (permalink) Old Aug 24th, 08, 06:43 PM
Chad
67 Plum's Avatar
I have the same info as Tim plus 11.8 cc dome volume , 634 grams and press or floating pins.
67 Plum is offline
post #10 of 16 (permalink) Old Aug 24th, 08, 06:49 PM Thread Starter
Tim and Chad, thanks for the info.
69z28302 is offline
post #11 of 16 (permalink) Old Aug 25th, 08, 02:24 AM Thread Starter
Bill as you can see I had the numbers wrong on the piston. The correct number is H102P Sorry
69z28302 is offline
post #12 of 16 (permalink) Old Aug 25th, 08, 11:23 AM
SY1
Mike I don't think I'd recommend 64 chamber heads to anyone wanting to use these. That's 12.1:1 static compression ratio if the deck isn't touched and 13:1 if zero decked. That's a recipe for detonation and a cast piston won't live long detonating badly if someone runs pump gas at that SCR. At 72cc you'd be 11:1 without factory deck height and at 76cc you'd be also at 11:1 if zero decked. But as you know you can run those kinds of SCR with flat tops and be better off without the domes. There is always a market for domed pistons however and you should have no trouble selling them.
I don't about the comment regarding KB pistons, but I am impressed with the attention to detail in the KB that I don't see in the piston posted.
"..............what, and get out of aviation??"
SY1 is offline
post #13 of 16 (permalink) Old Aug 25th, 08, 03:26 PM Thread Starter
I only takes a little lump on the 350 pistons to raise it a bunch.
69z28302 is offline
post #14 of 16 (permalink) Old Aug 25th, 08, 05:37 PM
Bill
Mike,
I completely forgot about this today But it looks like everyone else has it covered !
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #15 of 16 (permalink) Old Aug 25th, 08, 07:34 PM Thread Starter
Bill looks like there speed pro hypereutectic without the skirt coating. 350 0.040 over pistons with a .240 dome. 12 to 1 with a 64 cc head.
69z28302 is offline
