Exhaust Question (true dual vs X pipe) - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 25th, 08, 01:17 AM Thread Starter
Levi
Lightbulb Exhaust Question (true dual vs X pipe)
Hey guys I am just curious to know something. I really like the way the true dual exhaust systems sound, the exhuast hits ALOT harder I think. I have a x pipe on my camaro and its not as rumbley as a true dual. I take it this is normal right? I went with the x pipe for future preference in just having the exhaust ready to breathe the best.
so far I have for both is
True Dual - Louder, you can tell which side of the engine is burning oil or is acting up.
x pipe - Lets the exhaust scavenge better which leads to increased HP at a higher rpm.
So far thats all i got...anyone else want to tell me why the x pipe is better to have?
.Bad75. is offline
post #2 of 9 (permalink) Old Aug 25th, 08, 04:49 AM
Re: Exhaust Question (true dual vs X pipe)
Increased power is a pretty compelling reason, and it happens throughout the rpm range.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 9 (permalink) Old Aug 25th, 08, 05:57 AM
Kyle
Yeah the hp increase isnt only at higher RPM it should be pretty much from idle to redline i believe. that said the hp gain isnt that impressive .. but any hp gain is good hp gain
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #4 of 9 (permalink) Old Aug 25th, 08, 08:19 PM Thread Starter
Levi
does sounder nicer at high rpms though imo...
.Bad75. is offline
post #5 of 9 (permalink) Old Aug 25th, 08, 08:50 PM
Skip
Skeeter55's Avatar
Yeah the X-Pipe dose quite it up a bit.. But it sounds really tunned.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #6 of 9 (permalink) Old Aug 26th, 08, 07:42 AM
click's Avatar
Skip I see a smudge on the driveshaft wow thats clean
click is offline
post #7 of 9 (permalink) Old Aug 26th, 08, 07:56 AM
Skip
Skeeter55's Avatar
Thank you Jim . Its easy to whipe off when you have a car lift.
post #8 of 9 (permalink) Old Aug 26th, 08, 08:25 AM
My question is why?
Why does the X pipe increase hp?
I had no X pipe on mine and when I went with a new exhaust (using the same mufflers but new headers and exhaust) the guy talked me into an H pipe sort of thing which is what he put on his drag race customers cars.
I was a non believer. I couldn't understand why one side of the engine would care or how it would be effected by the other side of the engine's breathing.
The car was notibly quieter, idled much smoother or rather the car didn't shake as much with the cam I have in it, which is very lumpy.
And, at the track, I did an 11.60 or so several times. It sounded different and behaved differently at rpm. The wind up was smoother in a way. I guess I can't find the right word I'm looking for but suffice to say, I believe now.
But I still don't understand the theory as to why this works.
Can someone enlighten me?
mkpatrick is offline
post #9 of 9 (permalink) Old Aug 26th, 08, 09:11 AM
The x-pipe basically terminates the collectors, in the same manner that the collector terminates the primary tubes. With a 'true dual' system, the termination occurs at the end of the tailpipe. The secondary scavenging wave is created at this point, and tends to be more timely with the shorter collector. With the pipes tied together, there is a pulse created in the junction every 90° of crank rotation, as opposed to the uneven timing of the conventional duals.
Here's a link to an old thread on this board that deals with exhaust system design:
https://www.camaros.net/forums/showthread.php?t=16596
