Engine mounting bolt size - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 25th, 08, 10:06 AM Thread Starter
What is the correct length and tread of the engine mounting bolt for4 a small block chevy?
1968 Camaro Ragtop 4 speed
Chilli is offline
post #2 of 8 (permalink) Old Aug 25th, 08, 12:21 PM
Re: Engine mounting bolt size
the big one that holds the engine mount to the frame mount?
it's 7/16" coarse thread bolt that's about an inch longer than the width of the mounting ears.
you don't plan sincerity.
novaderrik is offline
post #3 of 8 (permalink) Old Aug 25th, 08, 07:50 PM Thread Starter
do you know what that width is?
Chilli is offline
post #4 of 8 (permalink) Old Aug 26th, 08, 03:30 AM
not right off hand, but it's easy enough to figure out if you have a tape measure.
post #5 of 8 (permalink) Old Aug 26th, 08, 06:16 AM Thread Starter
I was hoping to be able to pick them up before going out to work on my car since I do not keep it a my house.
Chilli is offline
post #6 of 8 (permalink) Old Aug 26th, 08, 03:30 PM
The shank length is 3 7/8. Total length is 4 1/8 end to end.
sspecialk is offline
post #7 of 8 (permalink) Old Aug 26th, 08, 07:00 PM Thread Starter
thanks , I picked up 7/16-14 x4 with 2 flat washers and 1 lock washer per bolt
Chilli is offline
post #8 of 8 (permalink) Old Aug 26th, 08, 07:23 PM
I just hapened to have mine at work today cleaning them up for the engine install to come soon. SOunds like you got the right ones
