69 RS vacuum question (& LOOK AT MY VALVE COVERS) - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 26th, 08, 11:25 AM Thread Starter
Kevin
I am running a holley 650 w/electric choke on my 383 motor. Edelbrock performer (eps) intake. (motor is new and not in my 69 rs yet)
I had the vacuum T behind an edelbrock carb on the old motor. This T had a 3/8 line to the brake booster and a 1/4 line for the vacuum headlights.
With the holley carb I cannot fit this T back on the manifold.
I dont want to use a spacer as I already have the hard fuel lines in place.
I also know there is a edelbrock #8096 that will fit under the rear of the carb but I was told that this is just a 1/4 inch line and not 3/8 for the brakes.
anyone have / had the same problem?
69Rook is offline
post #2 of 14 (permalink) Old Aug 26th, 08, 09:12 PM Thread Starter
Kevin
Re: 69 RS vacuum question
Also have a pvc vacuum at the rear of the carb
69Rook is offline
post #3 of 14 (permalink) Old Aug 27th, 08, 11:13 AM Thread Starter
Kevin
Re: 69 RS vacuum question (AND LOOK AT MY VALVE COVERS)
I have no replys so I thought I would add 'look at my valve covers' as this has 5 pages with 75 replys, and over 3048 hits.
69Rook is offline
post #4 of 14 (permalink) Old Aug 27th, 08, 01:00 PM
Andrew
Andrew69's Avatar
Re: 69 RS vacuum question (& LOOK AT MY VALVE COVERS)
I am disappointed that I can't see your valve covers. But.... I have not had this same problem but you might be able to lift your carb a little, install the "T", and then set the carb back into place. Another possible option may to insert a 90 degree elbow into the intake, and then mount the "T" toward the back.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #5 of 14 (permalink) Old Aug 27th, 08, 03:45 PM
AJ
Getting rid of some of those thread wouldn't hurt either.
You probably don't need any more than the part that has thread tape on it.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #6 of 14 (permalink) Old Aug 27th, 08, 06:14 PM
You sure don't need all those threads. A dremel with the cutting disk will make a smooth cut. You could also grind some off the top if it's thick enough.
bmisencik is offline
post #7 of 14 (permalink) Old Aug 27th, 08, 06:49 PM
Andrew
Andrew69's Avatar
Those threads are tapered. Shortening the length of the "T" won't let it screw down any deeper.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #8 of 14 (permalink) Old Aug 27th, 08, 07:25 PM
Joe
I love your sence of humor...I guess sending in pics of valve covers is easier than diagnosing your problem....The 90 deg. elbow solution from X33D80 sounds like the ticket to me.
Z282NV
1969 Camaro
Z282NV is offline
post #9 of 14 (permalink) Old Aug 27th, 08, 07:48 PM
But, a half to 3/4 turn of the correct pipe thread tap in the manifold and cutting off the threads would work.
post #10 of 14 (permalink) Old Aug 28th, 08, 01:05 AM Thread Starter
Kevin
Yes it is tapered, ..I will first look for a 90 deg elbow.. it may look a bit funky but it will be hidden. If that doesnt work, I like the idea of cutting some of the threds and grinding off some of the top.
I guess I thought there was some way / part that would make this an easy fix like a low profile vacuum T similar to the one in the pic. Thanks all.
69Rook is offline
post #11 of 14 (permalink) Old Aug 28th, 08, 08:30 AM
You should run a 1" spacer on your carb. It would more than likely make your motor run better, but I don't know the theme of your engine compartment. A 4 hole will give you more low end torque. Just make sure and match up with intake. 4 hole for a dual plane and open with open (actually, you can run a 4 hole with an open...just don't run an open spacer with a dual plane).
dubs68camaro is offline
post #12 of 14 (permalink) Old Aug 28th, 08, 09:10 AM
Andrew
Andrew69's Avatar
As Everette said, you could tap the hole a little deeper so that the "T" installs deeper, and you really wouldn't have to trim the length of the "T". Just be careful that you don't tap too deep or the "T" won't screw tight. Looks like you have lots of options.
I would still like to see your valve covers......
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #13 of 14 (permalink) Old Aug 28th, 08, 01:16 PM Thread Starter
Kevin
Here are the valve covers as promised. Please try to keep the drooling to a minimum as water may damage your key board. lol
69Rook is offline
post #14 of 14 (permalink) Old Aug 28th, 08, 02:30 PM
Andrew
Andrew69's Avatar
Thumbs up Re: 69 RS vacuum question (& LOOK AT MY VALVE COVERS)
Them's some nice valve covers you have there! I didn't realize that the engine is still out of the car, you have a lot of room to work and do this right.
Darn! Now I gotta buy another keyboard!
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
