cam question for pdq67 ? - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 26th, 08, 07:28 PM Thread Starter
Bill
I know you are very fond of the GM 30-30, #346 cam used in the 327 / 365 horse Vette engine. I know you are also very fond of the Elgin 30-30 cam #E-1133. The Elgin cam has all the same specs as the GM cam except for the lobe centers. The Vette cam is 114 degrees while the Elgin cam is 109 degrees. Keeping everything on the engine the same, what will the performance difference be with the Elgin cam? Is the idle rougher, is the vacuum much lower, what about the engine torque operating range?
Thank you,
Bill
sbcBill is offline
post #2 of 5 (permalink) Old Aug 26th, 08, 11:57 PM
Ron
Re: cam question for pdq67 ?
pdq67 were are you - LOL
The 114 LSA will deliver a much broader torque range and very suitable for Standard Transmissions and Road Racing where clutch feathering is important and Marine use. The 109 LSA will rev a little higher with less torque on the bottom to mid range and should peak with slightly more Hp, more suitable for Automatics on the street or 4 speeds at the Strip.
I personally love a 112 LSA with a 4 Spd and would tend to think a 114 LSA nearing Blower Specs or Off Road, but then you got to consider ramp and lift.
The bark of a 112 or 114 LSA cam has one sweet note.
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 5 (permalink) Old Aug 27th, 08, 06:25 PM
He, He!!
I was in bed last night at this time!
Anyway, right and GENERALLY!
A wider LCA = a lower o/a power peak and higher on both ends on the rpm scale for a longer usable power rpm range!
Narrower LCA = a higher peak power point, but lower on both ends on the rpm scale for a shorter usable power rpm range!!
Please consider these two cams!
The old 30-30 at
254/254, 114/112, .455" net lift solid lifter stock cam and
Isky's old Z-30 spec'd;
250/250, 108/108, .455" net lift!!
Imho, the old 30-30 is a great wide power producer in a 375hp/327 FI engine BUT the Z-30, due to it's narrower LCA is better b/c it will still pull way up there and the midrange t is higher!!
pdq67
post #4 of 5 (permalink) Old Aug 27th, 08, 07:44 PM Thread Starter
Bill
How will this affect the useable vacuum the engine will produce? I am trying to learn and understand the basics of selecting a cam for a car engine. When I worked in the business world in the engineering room I used cams (eccentrics) all the time to actuate and transfer mechanical movement. The difference in the engine are the many dynamics that are occuring when the engine runs through its entire RPM range. The equipment I worked with generally operated at a constant speed and only moved various component parts of the machinery. Vacuum and RPM were a non issue in my cam designs.
Bill
sbcBill is offline
post #5 of 5 (permalink) Old Aug 28th, 08, 04:26 PM
I don't have any real experience, but I figure anything past 111/111 will be fine and that is why the old 30-30 cam is 114/112.
If you really dig into cam cat's through the years, the bigger cams were usually 112/108 to 114/110 to 116/112 b/c of what you are talking about!
I think history will bear me out here when I say that I think Isky revolutionized the industry when they came out w/ their 108/108 Mega cams for STREET use b/c prior to that time, their cams were like 112/108 b/c of vacuum, but you can leave so much power on the table..
Check their 270-HL vs the 270 Mega and you will see what i mean.
pdq67
