Is my carb big enough for a cam upgrade? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 26th, 08, 10:14 PM Thread Starter
Current setup is a 350, forged pistons, port/polished stock heads, edelbrock manifold, 1 5/8" headers and Holley 670 Avenger, 9:1 CR and TH400 with 2500 stall.
I am runninga Comp Magum 280H Flat Tappet Cam
230/230 @.050" lift
valve lift w/ 1.5 rockers .480/.480"
LSA 110
I want to get more RPM and rougher idle without loss of driveability. I am considering a Comp 286H
236/236 @.050"
valve lift .490/.490"
LSA 110
Will my Holley 670 give me enough fuel?
1967 Camaro, Indigo blue, LS3 & 6L80 trans
2009 Cadillac CTSV Kooks headers with Corsas, intake, tune, 20" Forgeline ZX3p's 532 rwhp/517 rwtq
Ross Racing is offline
post #2 of 3 (permalink) Old Aug 26th, 08, 10:17 PM
Steve69SS396's Avatar
Re: Is my carb big enough for a cam upgrade?
Yes.
Steve69SS396 is offline
post #3 of 3 (permalink) Old Aug 26th, 08, 11:49 PM
Ron
Sounds like a Good Combo for a 350. I would go any bigger on either the Carb or Cam. A 327 and 302 can take a bigger Carb and Cam but generally run a 10.5:1 Compression to make Hp at higher revs for lack of torque.
This was my 70 1/2 Z28
Z15CAM is offline
