72 Z/28 Holley 6239 question......supposed to be a 2nd metering block? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 26th, 08, 10:42 PM Thread Starter
I just picked up a Holley 6239 780 carb that is supposed to be correct for a 72 Z/28 or Corvette LT-1. I'm not sure if it's all there though because it has a secondary metering plate, like a 600 and not a metering block. Was there ever a time when Holley made these with the plate and not the block?? All the ones I see on eBay have the block. Thanks!
dubs68camaro is offline
post #2 of 4 (permalink) Old Aug 27th, 08, 04:38 AM
Re: 72 Z/28 Holley 6239 question......supposed to be a 2nd metering bl
Hmm, my Chilton's Camaro Repair & Tune-Up All Models, copyright 1974, shows a 4150 style carb, secondary metering block, for the '72 Z/28.
post #3 of 4 (permalink) Old Aug 27th, 08, 06:22 AM
Eric
The 6239 is a 4150 style carb (uses a secondary metering block instead of a plate)
The metering blocks should be a 6828 on the primary and a 4519 on the secondary for a 1st design carb (List 6239), or a 7102 primary and a 7101 secondary on a 2nd design carb (List 6239-1).
Hope this helps.
Eric
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #4 of 4 (permalink) Old Aug 27th, 08, 07:37 AM Thread Starter
Hey Eric.....I have talked to you on the phone before!
The primary block is a 7102 62391. I guess I need to try and find that secondary block. There is a 6239 on eBay right now at $299 with a day to go and I paid $10 for this thing. Thanks for the info guys!!!!!
P.S. Anyone got a 7101?????
