Distributor Gear - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 28th, 08, 12:34 AM Thread Starter
Todd
Distributor Gear
I just purchased a Pertronix distributor for my new 350/330 hp GMPP crate engine.
The engine came with the stock HEI, but there is no room for the cap and I dont want to dent my firewall.
I understand that I need to use the melonized distributor gear, but what will happen if I use the stock steel gear on the pertronix?
The inside diameter of the HEI gear is smaller than the Pertronix gear...I guess I could have this machined to fit the Pertronix, but is there anyone who sells the correct diameter melonized gear for the Pertronix?
camarotoddd is offline
post #2 of 6 (permalink) Old Aug 28th, 08, 06:22 AM
Charlie
Re: Distributor Gear
Roller cams have to use a softer dizzy gear. There is no way around it.
67CamaroRS/SS is offline
post #3 of 6 (permalink) Old Aug 28th, 08, 06:42 AM
Matt
comp cams has gears. Or you could call performance distributors in Memphis.
'68 Camaro SS. Dealer for American made performance & restoration parts.
Check my site
chassisboy is offline
post #4 of 6 (permalink) Old Aug 28th, 08, 07:02 AM
parkbrau's Avatar
Todd,
Why call call Pertronix? Ask them whats up.
parkbrau is offline
post #5 of 6 (permalink) Old Aug 28th, 08, 08:16 AM
Unless GM (or you) has changed the 330hp crate engines to a roller cam, you do not need a melonized gear. All of the previous 330hp crate motors had hydraulic flat tappet cams in them.
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #6 of 6 (permalink) Old Aug 28th, 08, 08:55 AM
TC
I'm couious how Summits Dizzy "Summit SUM-850055" is an iron gear and compatible with both flat tappet and hyd roller cams? How does this work. I have a ZZ4 motor with this in it.
1968 Camaro RS orig AC car, ZZ Fatburn, Doug's D368 Headers, Tremec TKO600 w/ Hurst Blackjack, 12 Bolt Posi 3:73 mulitleaf, SFC's, Budniks, Hotchkis, Magnaflow, etc
6Z8RS is offline
