Need to raise my aire cleaner 2" - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 28th, 08, 08:05 AM Thread Starter
I need to raise the air cleaner housing 2-3" on my daily driver (sorry, it's not a chevy this time). I want to resuse the factory air cleaner so I can also reuse the factory cold air setup on it, but after I added the Mallory HEI (which is way bigger and taller than the stock distributor), my air cleaner no longer fits. Short of changing the distributor (which I don't want to do if I can avoid it), my only other options are either a much smaller diameter air filter (like 9" or less), or one of them cheapo foam air filters. I can find up to about 3/4" tall air cleaner spacers, but it isn't near enough. Any idea's where I could find such an animal?
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #2 of 5 (permalink) Old Aug 28th, 08, 08:16 AM
Re: Need to raise my aire cleaner 2"
Assuming this is an Edelbrock, Holley...etc, all you need to do is go to a local performance parts house and get a spacer. They make them in a variety of sizes and they go between your air cleaner and carb. I had to use one on my performer because the drop base hit the choke. 2" spacer and it was perfect. Didn't look too bad either!!!
dubs68camaro is offline
post #3 of 5 (permalink) Old Aug 28th, 08, 02:38 PM
Steps
If u dont have a lathe, head down to the local machine shop and get them to turn one down..its a small quick fill in job
I turned mine down for a custom air cleaner height.
Steptoe is offline
post #4 of 5 (permalink) Old Aug 29th, 08, 03:36 PM
Travis,
Will a piece a pvc plastic pipe fit??
pdq67
post #5 of 5 (permalink) Old Aug 29th, 08, 04:27 PM
DjD
DjD's Avatar
Phenolic spacer between the carb and manifold and a air cleaner base spacer will get you the height you want...
...Dennis
DjD is offline
