Q-Jet Idling issue - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 28th, 08, 10:51 AM Thread Starter
Q-Jet Idling issue
My Q-Jet seems to be acting up and I am looking for some advice. It is a divorced choke style Q-Jet. Start the car and it high idles for a few minutes once warm it drops down and it idles right at 800 rpms. After I drive the car, could be for a few minutes or an hour the idle takes a long time to come back down when I stop. At a light or stopped it will stay around 1100-1200 rpms for 45-90 seconds before it very slowly comes back down to 800rpms were I set it. Any ideas?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #2 of 8 (permalink) Old Aug 28th, 08, 11:43 AM
Re: Q-Jet Idling issue
What is your timing doing while the idle is taking 45-90 seconds to drift down to 800 rpm?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 8 (permalink) Old Aug 28th, 08, 12:14 PM Thread Starter
Not sure never checked while it is coming down. What are you thinking weights are getting hung up?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #4 of 8 (permalink) Old Aug 28th, 08, 12:35 PM
You could have weights hanging up or your VA can is not right for the engine.
post #5 of 8 (permalink) Old Aug 28th, 08, 12:45 PM
Another problem could be that it's a Q-jet and not a Holley.
SepsiS is offline
post #6 of 8 (permalink) Old Aug 28th, 08, 01:40 PM Thread Starter
Whole distributor is original so the vacuum can is right. I am going to go check under the cap now and see how everything looks under there and report back. Thanks.
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #7 of 8 (permalink) Old Aug 28th, 08, 02:28 PM Thread Starter
Everything in the dizzy looks good. I lowed the idle while it was running high down to 800 drove the car and it stayed up arounf 1100 again. Checked all the linkage and nothing is getting hung up. Must be a carb issue but what?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #8 of 8 (permalink) Old Aug 28th, 08, 04:59 PM
When it is idling fast check:
Is the throttle shaft hitting the idle stop properly:
Is the fast idle cam hitting?
Jiggle the linkages to see what might change the idle as a clue to the problem.
Distributor Vs carb problems can be hard to differentiate and both should be checked.
other than that maybe some gunk in the carb , but that will not explain the intermittant changes?
TTFN
Mat
SSCARGO
Mat Klemp is offline
