1969 Aluminum Intake bolt torque - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 28th, 08, 01:12 PM Thread Starter
Question 1969 Aluminum Intake bolt torque
I have not been able to locate the 1969 Z28 Aluminum Intake bolt torgue spec's. I located the spec's for a cast iron type-30ft pounds torque. Does anyone have the torque specs for the aluminum intake? Thanks for all answers ahead of time.
John L.
Chas, SC
jlighthart is offline
post #2 of 3 (permalink) Old Aug 28th, 08, 02:09 PM
"Tri-Tip"
Gary L's Avatar
Re: 1969 Aluminum Intake bolt torque
30 FT. LB. as well. No flat washers. Be sure to seal the threads that go thru.
Gary L is offline
post #3 of 3 (permalink) Old Aug 28th, 08, 02:20 PM
Vintage 68's Avatar
Thumbs up Re: 1969 Aluminum Intake bolt torque
Like GaryL said - GM recommended 30FtLb no matter what the intake material was.
For use with Aluminum heads they did reduce the torque spec. to 20FtLb.
Edelbrock recommends 25FtLbs.
I find anywhere between 25~30FtLb works well with the newer gasket types.
1968 Convertible
Some trucks
Vintage 68 is offline
