Cowl induction - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 29th, 08, 01:31 PM Thread Starter
Kevin
Cowl induction
I have a real cowl induction hood and was thinking about adding it to the car. Is this pricey- is there an easy-to-do kit that has all needed parts?-
I'm not sure all the steps involved- thanks
Kev68ss is offline
post #2 of 2 (permalink) Old Aug 29th, 08, 02:57 PM
Re: Cowl induction
if you want it to look factory, then you need to buy some expensive parts to make it work- air cleaner assembly, flapper parts, etc.- but if looking original isn't an issue, then you can just put the hood on the car and make an airpan to seal against the bottom of the hood using an aluminum cookie sheet and some foam.
you don't plan sincerity.
novaderrik is offline
