Crank and Water pump pulleys for 400 sb - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 31st, 08, 10:45 PM Thread Starter
Darren
This is driving me crazy. I have a long water pump on my 69 with a 400 small block. I need to know which pulleys to buy that will work for my set up. I only have no ac or smog pump. I just need to know which water pump and crank pully to run. Part number? Anything will help. Can't afford the march set up right now.
Thanks, Darren
Darren
67 Camaro 350
69 Camaro 406 10-1 comp, afr 195s, performer rpm intake, 750 DP, comp 286h
67CamaroD is offline
post #2 of 7 (permalink) Old Aug 31st, 08, 11:10 PM
Jon
Re: Crank and Water pump pulleys for 400 sb
69's came with long water pumps. Stock 69 pulleys would fit just fine on a 400 as they would on any size small block. You could probably use the pulleys off of any 69 and later Chevy car (except Corvette) or 73 and later truck engine that has a long pump. If you want the part numbers for a 69, look over at camaros.org
Jon N
dyno jonn is offline
post #3 of 7 (permalink) Old Aug 31st, 08, 11:13 PM
There are a whole bunch of them on Summit. Just have to go through and search by engine and then put in how many grooves you want them to have.
SepsiS is offline
post #4 of 7 (permalink) Old Sep 1st, 08, 12:21 AM Thread Starter
Darren
Thanks guys.
Darren
67 Camaro 350
post #5 of 7 (permalink) Old Sep 1st, 08, 12:38 AM
get to the nearest junkyard and start popping hoods on 70's Chevy pickups- they are the most likely to not have the extra grooves for things like AC compressors and AIR pumps.
if you were local to me, i'd give you the stock pulleys off my 74 Monte, since i have a serpentine setup off a 92 Caprice in it.
you don't plan sincerity.
novaderrik is offline
post #6 of 7 (permalink) Old Sep 1st, 08, 01:03 AM Thread Starter
Darren
Thats probably the best bet for me. I am looking for the cheap route for now, until I have the money for a serpentine setup.
Darren
67 Camaro 350
post #7 of 7 (permalink) Old Sep 1st, 08, 03:24 AM
while you are at the junkyard, pop the hoods on a few S10's and later model trucks and look for a complete serp setup. i can't see them wanting more than $100 for a complete setup- and you might find one that has a rebuilt water pump and alternator and possibly a newer PS pump.
