Any 327's with a Comp XE268H Cam? - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 1st, 08, 12:40 AM Thread Starter
I'm rebuilding my stock 327 and was planning on buying a Comp XE268H for street/strip use. Comp recommended the XE262H instead. WHen I read the posts on this terrific forum saying the cam didnt last, I'm now not sure what cam to get. If anyone is running this cam successfully, I would really like to know your setup and how you like it.
Thanks in advance,
smiller is offline
post #2 of 6 (permalink) Old Sep 1st, 08, 01:17 AM
Farm Boy's Avatar
Re: Any 327's with a Comp XE268H Cam?
I have the XE262H in my 327. My only complaint is the valve train noise it produces. It sounds like it has a bad lifter when idling. I tried adjusting the valves several times but the noise persists. I even tore it down but found nothing wrong. When the engine is cold the noise is not present.
I no longer worry about the noise. It idles well with a slight lope and pulls great up to 6500 RPM.
Would I buy another XE cam? No.
327 with flat top pistons and "462" heads
XE262H
Performer RPM intake
670 Holley Street Avenger
M20 Muncie
3.42 Posi
Farm Boy is offline
post #3 of 6 (permalink) Old Sep 1st, 08, 03:26 AM Thread Starter
FarmBoy,
Steve, thanks for the response. My second choice was the XE262H but I trust your judgement having read your posts on other matters.
smiller is offline
post #4 of 6 (permalink) Old Sep 1st, 08, 06:53 AM
Imho, 260/262 cam for a 9 to 1 CR'd 327/331/336 and a 268/270/272 cam for an about 10 to 1 CR'd 327/331/336 engine.
I personally like solid lifter cams so please consider an Isky Z-20 for the 9 to 1 engine and the Z-25 or Z-27 for the higher compressioned engine only b/c these short-stroke little buggers just love to rpm!
pdq67
post #5 of 6 (permalink) Old Sep 1st, 08, 02:08 PM
I like the 262. Much more streetable and probably makes a little more torque than the 268. I removed my 268 and replaced with an old style comp 260h. The 268 was noisy and would not idle smooth enough for an auto tranny.
I have found ALL Comp lifters to be noisy. (just me...perhaps)
I replaced my Comp 816 hyd lifters with a set of Johnson lifters.
Finally that motor stopped ticking!
Now runs like a scawled monkey!
74LS454 is offline
post #6 of 6 (permalink) Old Sep 2nd, 08, 01:30 AM Thread Starter
pdq67
You may have changed my mind toward solid lifters. I dont mind the idea of adjusting lash now and then and the more I hear about Comp cams and lifters, the more I want to find an alternative and an Isky or Lunatti may be it.
Thanks for the input
smiller is offline
